RacingRegal36
Got the charging system came up with a bad diode and that they failed. Also no misfire showing on the gauges
You could have the spark being blown out if you were on a crazy small pulley and flowing a ton of air....but with stock manifolds etc, those will hold back enough flow usually to keep that from happening.
Do you have a copy of the tune or access to a tuner that can pull a copy off the pcm? Agreed..you have very little oxygen up there. Greg should be able to pull the tune and see if that's the case easily.
