Scottydoggs
Killa Bee
Re: Got ****ed around on a craigslist deal please help
so your scanner lights up but wont scan the car?
A 2001 GP SE isn't worth $2150 as Scotty and others have pointed out, but what's done is obviously done. Check the rear strut towers, wheel wells, rocker panels, and underneath the gas door for rust: if all of those areas check out fine, then you might still have a decent car for a while.Ok so first of all i bought a 2001 grand prix se 3.1L for $2150
You didn't notice this first? Luckily window motors are easy. Use a T-25 torx bit or a 5/16 allen wrench to get the little bolt in the center of the door panel off, and then unbolt about a dozen 10mm bolts, and the window motor and regulator come right out. Don't forget the two that hold the regulator to the glass. Replace with a lifetime warranty part from the nearest auto parts store. I've replaced so many of them that I can get one out in 10 minutes now.I thought the kid was an alright guy until I noticed one of the windows were held up by a 2x4... he obviously knew that was wrong and didnt tell me so now I wonder what else is wrong with it and I assume the worst
That's beyond me. PCM issues perhaps? Bad axle/wheel speed sensor? Or the needle is broken (I know the gauges on some Chevys are known to go haywire but I haven't seen one on a Pontiac yet). Or you do even have the stock 16 inch tires? Maybe you have a bigger wheel?the speedometer reads 20mph off
Ahh, the infamous 3100 head gasket issues. Have fun... Make your old man wrench on the thing as payment for making you buy that car.there is oil in the coolant... I dont know if this is residue from a fixed head gasket or if the LIM is eaten away and the oil is leaking into coolant because there is no coolant in the oil.... or if i have a cracked head or block...
I'm surprised Scotty hasn't copy pasted his coolant flush technique yetIm planning on doing a flush tomorrow
