Jomamma's Bagged Red 97 GTP | Somethings Always Broken |
Re: Jomamma's Red 97 GTP AKA Horace *Front Bags Installed* (Oh god the rake!)
I'd buy the widest wheel you can.
And the cheapest tires.
And then just rip the fender apart.
Man idk how far you want to push your fenders, but I think the 18x9.5 +12 or the 19x9.5 +12 would fit perfect. depending on your tires too.
the offset isn't gonna matter a ton, but i'd think i'd go ahead and go for the 18x9.5 +22mm set.
then you have to figure out what kinda dumb tire you want to run on it. 225/45?
I think those would fit on the rear perfectly. But I think they would poke out too far in the front.You only had spacers on the rear right?
I'd like to run a wider tire but that's probably not going to happen without sacrificing low.
And then slap some damn CTS-V calipers on dat b!*ch :th_thumbsup-wink:
Reminds me of my old 97 GT and had a set of cce hydraulics on it, could set the rockers right down on the ground, i miss that car, lol
i will find some tomorrow, but your car is looking awesome, keep up the good work
Thanks.
The rear bags are going in tomorrow or wednesday. Its raining both days, we just have to which day is going to rain more.
Yeah, it was 18x10 +25 all around and then 10mm spacers to make it 18x10 +15 in the rear. I think the half inch less width and extra offset would make it about identical. But i guess it would be nice to have a little extra room to add or subtract spacers as you'd like
18x9.5 +12 will poke 6.6mm more than 18x10 +25
18x9.5 +22 will poke 3.4mm less than 18x10 +25
hmm, the +22 ones seem like a good bet then. Can you check the difference on the inside clearance? Mine almost hit the trailing arms so hopefully that doesn't bring them inside any further
see....told ya i'd go with the +22 version, hah.
Yeah there will be plenty of inner fender room.
Sent from my DROID RAZR using Tapatalk
PS - i enjoy that you actually cracked open a calculator and figured out numbers. it's not all that hard when you understand what the specs are and have another set to compare to.
Yes, the internet also helps tons lol.
Wired up the gauge today.
I wish it was red :(
swap out the leds...or just buy a red one lol
or sell car and buy a Juke... they have red leds all over the place!!
