Sway end links will probably break into lots of peices, I need sway bushings should have did it when I did LCAs and tie rods and sway ends. Good luck replacing stuff. My moogs looked different odd.
Sent from my Galaxy Tab 3 8.0
Why you replacing it all? or is the old stuff just worn right out
How difficult were the control arms to install? And do you have to get an alignment after doing them?
They were easy, I'll get an alignment after all the work is done.LCAs are easy, 4 bolts and its off. I did both sides of mine including sway bar end link and tie rod ends in 1 and half hours per side. Most of thd time was hunting for tools. Iv heard you don't need an alignment after LCAs but I would do it as insurance.
I wouldn't worry, that's what I did. If you remove the Axle remember to re torque the Axle nut back to 118ft/lbs I believe it is.The only issue is you have to remove the cv axle to torque the lower ball joint nut. I didn't do it, I just tightened as much as I could with the wrench. Maybe I'll remove the axle and do it when I replace the tie rod end.
