Because you set the PE table to 11.5 and zero'd out the others, it will not add anymore fuel based on time in PE mode.
Though I've seen go slighty richer on its own by a little bit with those tables zero'd.
If you want to add fuel back, just pick the rpm range and time frame and add small amounts. Your numbers will add to the current commanded AFR, so do like .100 to .900 to get it down into the 10's.
I see what you mean. I basically "hacked" the maf table to compensate for what I have 0'ed out. With what you stated then is PE even functional now?
Trying to understand these tables is a bit confusing as for a v8 they have a PE vs RPM which is a super easy layout to modify unlike our cars.
These are the stock files below. With a little reading in the hpt help I am still a bit confused.
--Power Enrich Fuel Adder vs. Throttle Position Sensor-- This table adds to the base AFR in relation to throttle position. It is generally used to lean the fuel at smaller throttle settings.
--Power Enrich Fuel Adder vs. RPM vs. Time-- This table adds to the base AFR in relation to RPM and time in PE mode. It is used to provide additional RPM and time based enrichment and is similar to the PE vs RPM table on V8 engines, but with an additional time component. Remember, this value adds to the Base PE AFR so positive numbers here are leaner and negative numbers are richer.
Enrichment Rate: This is the rate at which Fuel is added to reach the desired enrichment value. The smaller this value is, the slower the VCM will reach the desired PE AFR. For instance if your non pe commanded EQ ratio is 1.0 and your pe commanded EQ ratio is 1.300 and your enrichment rate is set to .3 it would take 1 step ~10ms for most pcms to reach full PE.
In stock form we have a commanded afr of 12.4 at operating temp which is lean. Now in the Fuel Adder vs. TPS we have 0 after 70% so it does not lean anything out. What if I left the stock values up to 15 tps %, will this net me better mpg's at all? Should I really be touching this area at all? Next we have the Power Enrich Fuel Adder vs. RPM vs. Time. This is super confusing due to the layout and not understanding the numbers. We can all agree that from the factory the cars run rich for safety. With that being in mind it is right around 10.8 afr at wot I would guess. We have that 12.4 commanded afr and according to the chart a -1.000 to -3.000 in the 5600-6400rpm to make things richer. Do these numbers have an actual value meaning? How will I know exactly which area to have a + or - number in the correct column according to seconds? I would like to put my stock maf back in with table, leave it alone and tune this table instead. Will fuel trims be affected by this table when not in PE? Will some maf tweaking still need to be done in the lower half to compensate?
