REDCRAPGP
Hunting for used 97-03 LCA's and aftermarket sway bar.
Aren't they like $100 new from RA anyways for that price why buy used..
All 06+ GP are strut mounted sway links, not just gxpNah All three years of Gxp use strut mounted sway bar endlinks
You wan a bigger rear sway before you want the front and if you want coilovers you can still use what youd have to for the rear which is a bracket that connects to the knockle instead and custom end links or universal ones from white line racing.They do indeed. So if anyone with a GXP wants a front sway bar or coilovers they need the older style LCA's![]()
Edit and to be honest I like the way handled better with the strut mounted sway back links. I'll probably be going back to the style towards the end of summer.
Good deal you converting the bilstein to coil over?I know. For now I just want the LCA's and the GMPP front sway bar. GXP's come w the GMPP rear sway bar. So I'm
k w leaving the rear sway bar alone for now.
Gotcha well you could save more money and just buy the parts and do it yourself about 175 and all you really need is. Angle grinder and basic hand toolsHadn't thought of doing that. Was gonna buy Held coilovers then sell the Bilstiens with the CCS springs to cover some of the expenses.
And fwiw the bilsteins are a way better shock to handle the increased spring rates. Mono tube is the way to go. There lighter as well
