Right now I'm having an issue with my 02' GP GT. The passenger side blows cold air on AC but the driver's side blows hot. Does anyone know the part number for that Actuator Motor. I'm assuming it needs to be replaced. Thanks. I'm tired of driving with the driver's side vents shut and turning all the passenger side vents my direction. It's getting too hot these days for that kind of nonsense. I'd rather sweat my azz off for one day repairing it.
I had the exact same symptoms on my '03 GT, turns out it was the refrigerant level was low, not the actuators. Worth a check, it's an easy fix if that's the problem.
If you need an actuator, RockAuto has the best price by far.
Good luck!
you can pop the d/s actuator off and then turn the knob by hand, if you can make it blow cold manually the actuator is bad.
if its still warm, the system is low for sure. but you got the a/c gauges so you can also test the line pressures.
and its been f ing hot here the last few days.
not sure what the difference its either, you got lkq parts right down the road from you, go ask them for a used one. LKQ Hunts Point Auto Parts
first post of this thread is the how too to change them. drivers side is a bit tight. but very doable. i wear size 3 x gloves, so i got large hands, yes i bled a little, but i got em in and out. more then once sadly lol
I guess I spoke too soon! I get downstairs this morning and hit the AC Control and the passenger side is ice cold but the driver's is still running warmer. Big difference though from before, just not as cold as the other side. So I guess I'll be under the dash this weekend!
Was it up to the proper charge pressure for the ambient temp? When I got mine to spec, the drivers side ended up slightly cooler than the passenger side, go figure...
