LS1GTP
It's Slow
Good write up. I attached mine at the back a little bit differently. I might take mine back apart and do it the way you did it so i can get some more adjustment out of them heightwise. Looks good
Heightwise? If you need to adjust them up and down, why don't you use the adjuster on the headlight bracket?
This may be a dumb question but, did you take out the projector when you painted? and did you paint the shroud too?
What did you mean by "Cut that sucker off, at an angle where the projector will be angled "outward"."
Yes, the projector wasn't in the housing when I painted. Painted the shroud also.
Cut it so if you had a bulb there, it would face outward, away from the middle of the car. If not, the beams may point too much toward the middle of the car and cross each other. See what I'm saying? It was hard to explain.
