Thread: Seeing some medium load KR
Results 1 to 3 of 3
  1. #1 Seeing some medium load KR
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    With the aeroforce installed, I now notice that at medium engine loads (roughly 50% throttle or so), I can see blips of KR up to ~2 or 3 degrees. This goes away to 0*KR then all the way up through shifting as I lay into the throttle more going to WOT. The fact that I get some mid-throttle KR but none at WOT even up past 5500rpm seems a bit odd to me. At first I thought it was false KR due to downshifting perhaps, but now I realize I notice it on occasion just gradually getting into the throttle. Again, the motor is nowhere near building full boost when this KR is seen. I also have poly upper motor mounts (and all the other mods in the sig).
    Let me know what you think! Anyone had this particular issue before?
    Edit: Note that my AFRs become "enriched" just before I get into any boost so I think we can eliminate an early boost lean condition as a potential root cause
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  2. #2 Re: Seeing some medium load KR
    Feb 2009
    flintnasty MI
    Too rich can cause knock.. try taking some out of the first few time rows in pe vs time vs rpm
  3. #3 Re: Seeing some medium load KR
    Mar 2014
    Cincinnati, OH
    Good call. I am definitely on the rich side. I'll take some gruel out of those throttle positions
    2002 GTP sedan:
  1. 99 GTX Surges hard under medium throttle and randomly shuts off
    By VOChris in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2013, 04:41 AM
  2. SEM paint code for medium camel
    By tdm571 in forum Visual/Body Modifications
    Last Post: 05-05-2011, 06:40 PM
