Thread: Weird glitch with A/C switch
Results 1 to 5 of 5
  1. #1 Weird glitch with A/C switch
    SE Level Member AxelRod's Avatar
    Apr 2013
    Locust Grove, VA
    Hey guys,
    I'm working on a 2001 Grand Prix GT that was in an accident with a 3.8l N/A motor. I've run into a rather peculiar behavior in this car:
    I have blower speeds 1-4 on the A/C, which just started working out of nowhere after wiggling the fuses in the fusebox by the glove compartment, but 5 doesn't work. I checked the fuse for HVAC HI, and it looked fine.
    Now, here's the weird part....
    When I turn the switch to 4 and let it go for a little while, and then switch it to 5, the radio's display flashes on, the windows can work, and the display lights up on the mirror (Auto-dimming w/Onstar), all for a split second before those things go blank again and don't work.
    Any ideas for what's going on?
  2. #2 Re: Weird glitch with A/C switch
    St. Louis
    Sounds like there is a wiring/ground issue somewhere. How bad was the accident? Any of the wiring under the hood get damaged, or possibly from airbags deploying?
  3. #3 Re: Weird glitch with A/C switch
    GT Level Member ShadowSwept's Avatar
    Kentucky
    I had a problem with my SE (3100) where the A/C only worked on 5, and setting it on 1-4 would shut off the headlights. Replaced the blower motor after trying everything else and it worked fine.
    2001 Bonneville SLE - L36, Cone Filter, 200k miles
    2003 Grand Prix GT
    - L36, Short Ram Intake, HV3, Emissions Delete, ZZP 3" Downpipe, Overkill Tune, 200k miles
  4. #4 Re: Weird glitch with A/C switch
    Apr 2013
    Locust Grove, VA
    Thanks for the replies. The accident caved the nose of the car in (hit a tree) and the airbags deployed. I've since replaced the dash, and the only thing I noticed was damage to the airbag cable that runs from the driver's side to the passenger side, and that's already been fixed. I'll look into it more once I get the car restored.
  5. #5 Re: Weird glitch with A/C switch
    Apr 2013
    Locust Grove, VA
    Well, I got the car put back together after helping my dad weld in a new core support, and upon reinstalling breakers for the headlamps and the cooling fans, everything started working again, and all four windows work along with all five blower speeds. . The previous owner had removed those breakers for some reason after the accident. Now I just have a dim DIC, which could be just bulbs. Thanks all!
  1. weird glitch with my rpms
    By mikedinthecity in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-05-2012, 05:19 PM
  2. On star glitch
    By NashGT02 in forum General Tech Discussion
    Last Post: 03-04-2011, 07:41 PM
  3. Trans switch/ e brake switch
    By Halbs in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2010, 02:57 PM
  4. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
  5. is this a glitch?
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 07-18-2008, 01:17 PM
