Im on the path to running the 3.4 pulley and my next mod is going to be ether down pipe or possibly power log. I would much rather get a u bend delete being as the price for the down pipe (with cats) and installation.
I should be able to skate with a ubend delete and install for around $100.
Down Pipe is the way to go, but I was wondering if I could get away with just a ubend delete. The DP only runs about 100 but you need to get a cat with em.
What option would I use from zpp's down pipe so I could use my cats? would the have to be welded on or bolted on?
Also with the power log, you will need to get the gasket with it correct?
