Thread: Guess that noise
Results 1 to 20 of 25
  1. #1 Guess that noise
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    Not sure what kind of noise this is. It's coming from the front end, near the valve cover/exhaust manifold
  2. #2 Re: Guess that noise
    Exhaust leak?
    Loud pulleys?
    Kinda hard to tell if anything is wrong.
  3. #3 Re: Guess that noise
    Nov 2011
    Indiana
    Loud pullies yes lmao. But every time i rev it you can hear that rattling/tick like noise? can you it when the car drives by too, its pretty loud.
  4. #4 Re: Guess that noise
    Nov 2011
    Indiana
    This does have SD headers, so idk if its just the brand, or a leak. or noise coming from the valvetrain
  5. #5 Re: Guess that noise
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    I'd pull the valve covers and inspect.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  6. #6 Re: Guess that noise
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    Quote Originally Posted by dbextreme View Post
    X2
    could be alot of things
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  7. #7 Re: Guess that noise
    Nov 2011
    Indiana
    Well, i guess i can live with it now. Ill be pulling the engine for the cam, so might as well check then and replace the gaskets and all the valve train parts.
  8. #8 Re: Guess that noise
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    sounds like a valetrain rattle, might wanna check sooner. its free to remove the valve covers
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  9. #9 Re: Guess that noise
    Nov 2011
    Indiana
    the thing is, the rattling goes away after a second or two. like at cruise its gone, then you get on it from cruise and no noise. But when you let off the pedal/gas then rev it/give it gas it comes back real quick then goes away. I think it's exhaust related on that note.
  10. #10 Re: Guess that noise
    Florida
    Go check and see if either of your belt tensioners are shot.
    Sounds like the S/C tensioner smacking around. (Just replaced mine about 2 weeks ago, same noise)
    Should be able to visually see the tensioner moving to lock
  11. #11 Re: Guess that noise
    Nov 2011
    Indiana
    when i put my ear around the front manifold by the spark plug and move around it seems to be pinpointing from that location.
  12. #12 Re: Guess that noise
    Nov 2009
    Tennessee
    I know my laptop speakers suck, but that sounds mechanical not exhaust related!!! Like Seachicken said, pulling valve covers are free. You can check for loose rockers, gaps in pushrods to rocker arms, broken valve spring, broken guide (or whatever the piece is the rockers sit on), messed up lock ect... How does the car run when the sound happens as you drive? Any miss, sputter, or still smooth running?
    But I guess dropping an exhaust valve could be exhaust related...
  13. #13 Re: Guess that noise
    Nov 2011
    Indiana
    just wondering, but if it was valve train related, wouldnt you hear it all the time? and not just the first few seconds of giving it gas then the sound goes away?
  14. #14 Re: Guess that noise
    Florida
    ^ If he dropped an exhaust valve, there would be a much more profound noise, and severe lack of compression.
    So is the car Supercharged or no? If so, pop the SC belt off, rev and see if the noise goes away.
    If its not supercharged, check the serpentine belt tensioner. Easiest things first. If not, listen to the valve cover.
  15. #15 Re: Guess that noise
    Nov 2009
    Tennessee
    Not if a lifter is going dead..
    I've also seen broken springs make sounds like that. The spring will get in a bind and go quiet, then break free to rattle, shift and sieze again. Guy at work had a Dodge Van that did it.
  16. #16 Re: Guess that noise
    Florida
    Could be a binding/cracked valve spring. Doubt it though.
  17. #17 Re: Guess that noise
    Nov 2011
    Indiana
    hmmm....i guess its starting to sound like a valve train problem. I guess ill have to replace everything when the time comes. Can't really be positive as of now tho. But I'm 99% positive is the the SC or or the belt tensioner
  18. #18 Re: Guess that noise
    Nov 2009
    Tennessee
    ^^^ someone didn't see the sarcasm.. :-/
    I said it sounds mechanical, not exhaust related. Tensioner is a mechanical sound to.. SC tensioner is under the ICM, puts it at the front valve cover. Very plausable. I'm just leaning toward valvetrain based on his description of the location..
  19. #19 Re: Guess that noise
    Nov 2011
    Indiana
    At first i thought it was the spark plug cover rattling against the header, but there's no metal to metal contact.
  20. #20 Re: Guess that noise
    Florida
    JD, is the car sitting outside at the moment?
    If you have a flashlight and a key, you can start the car, and watch the tensioners while you rev the engine. This takes roughly 34 seconds. (I replaced both tensioners, and put new belts on in a parking lot in under 5minutes, so I know you can)
  1. Guess What?
    By fri3dchick3n in forum Off Topic Discussion
    Last Post: 04-23-2011, 01:09 AM
  2. guess what i got?
    By gtpinsc in forum Off Topic Discussion
    Last Post: 01-20-2011, 08:04 AM
  3. Who can guess what happens next?
    Last Post: 07-09-2008, 02:44 PM
  4. Guess what i did
    Last Post: 06-11-2008, 10:58 AM
