Thread: Shaky steering wheel
Results 1 to 11 of 11
  1. #1 Shaky steering wheel
    Dec 2010
    DMV
    Ok, I had a little incident two days ago (3 studs snapped due to me not paying attention and rushing smh).
    Ok i put a new wheel hub on because mines was under warranty. Now I've noticed that the wheel is crooked (it was before but now it's even more noticeable) and now my steering wheel shakes at speeds over 35mph.
    What else did I break? I will admit that I had to drive the car to the shop with the snapped studs but I did take it slow and avoiding pot holes at all cost. I did notice while changing the hub bearing the hub ring that sits in the rim was pretty banged up. Could that be the issue? Any other ideas? I'm hoping the rim isn't bent. But that's unlikely because I checked wheel and didn't notice anything. Maybe a more thorough inspection is due. Thoughts?
  2. #2 Re: Shaky steering wheel
    tennessee
    jack it up enough to get the tire off the ground then with one hand on top and one on the bottom and try to move it back and forth if it moves thatll tell you if they gave you another defective hub then try the same thing but with one hand towards the front and one towards the back if it moves thatll tell you if your tie rod is bad... both will cause vibrations
  3. #3 Re: Shaky steering wheel
    i think you may have bent your rim, rotate it to the back see if the wheel feels better.
    if it does fell better take the car and have the wheel balanced to see if/ or how bent it may be, and if its fix able.
    Dec 2010
    DMV
    Crap. Hope it isn't a bent rim . I will check it out in the am
    Dec 2010
    DMV
    Ok quick visual inspection shows that the wheel is shifted outward bit at an angle. I'm guessing an axle?
  6. #6 Re: Shaky steering wheel
    more likely a bad hub.
    jack the wheel up, see if the wheel has play, grab it at the top, and give a firm push /pull. it should be tight feeling.
    or for what ever reason, your alignment is out.
    Dec 2010
    DMV
    Yea I noticed the alignment is shot and the hub is new so I'm guessing a faulty hub or something isn't tightened correctly
  8. #8 Re: Shaky steering wheel
    tennessee
    umm which part of the wheel??? top, bottom, front or back??? still thinking tie rod or maybe control arm??? what kind of "incident" are we talking about???
    Dec 2010
    DMV
    Bottom part is shifted out. Loose lugs nuts, three snapped studs, new hub. Incident highlights lol
  10. #10 Re: Shaky steering wheel
    tennessee
    bent control arm??? rims are hard to bend... and i meant how it happened not what happened
    Dec 2010
    DMV
    Ok update, apparently for what ever reason there was two hub rings inside my rim. Which was making the rim not sit properly. After checking the wheel there was no bends which was great. I removed the extra hub and all is well. Alignment is needed though lol. Atleast it's not shaking anymore though
  1. Shaky steering wheel, loud snap!
    By Bluemagic in forum General Tech Discussion
    Last Post: 11-26-2012, 05:18 PM
  2. 05 steering wheel on a 99
    By Angelo1912 in forum Visual/Body Modifications
    Last Post: 06-13-2012, 09:40 PM
  3. I'd like a new steering wheel
    By gunsn88 in forum General Tech Discussion
    Last Post: 09-13-2011, 11:14 AM
  4. Steering Wheel
    By RideMr2 in forum General Tech Discussion
    Last Post: 05-27-2010, 11:41 PM
