Thread: Noise on first movement of car and when braking on slick surface
Results 1 to 6 of 6
  1. #1 Noise on first movement of car and when braking on slick surface
    SE Level Member ImColeTrickle's Avatar
    Apr 2011
    Athens, Alabama
    When I first start my car (1997 Grand Prix GT) and shift it into either Drive or Reverse and move a short distance it makes a strange... gargling noise. Thats the best way I can describe it anyway. It mainly happens just a few seconds after I let off the brake. And when it happens the lights flicker and I seem to lose a little voltage. And last year when I hit ice during the winter it made the noise several times when I was on the brakes coming to a stop. So Im thinking ABS? Anyone else have this problem?
  2. #2 Re: Noise on first movement of car and when braking on slick surface
    Ohio
    sounds like a growling gurgle?
  3. #3 Re: Noise on first movement of car and when braking on slick surface
    ABS doing a self check I would assume.
  4. #4 Re: Noise on first movement of car and when braking on slick surface
    Apr 2011
    Athens, Alabama
    Sorta... Its hard to describe but it happens everytime the car is started
  5. #5 Re: Noise on first movement of car and when braking on slick surface
    Oct 2011
    Toledo, OH
    Yeah, mine does it too, and this is it.
    7"
  6. #6 Re: Noise on first movement of car and when braking on slick surface
    Apr 2011
    Athens, Alabama
    Well thanks guys. At least now I know its not something about to break
  1. Grinding noise/feel when braking/turning
    By eponine997 in forum Brakes/Suspension/Chassis
    Last Post: 01-09-2011, 02:00 PM
  2. Knocking Noise While Braking
    By jonrk7 in forum Brakes/Suspension/Chassis
    Last Post: 10-15-2010, 02:14 PM
  3. Thumping noise when braking
    By 400exHauler in forum General Tech Discussion
    Last Post: 10-11-2010, 12:46 AM
  4. Grinding noise in reverse, then no movement
    By chantspel in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-06-2010, 08:08 AM
  5. Metallic noise that goes away with braking
    By kind153 in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2010, 03:32 PM
