Thread: ses light cycle time?
Results 1 to 6 of 6
  1. #1 ses light cycle time?
    '02 GTP oneil.GTP's Avatar
    Oct 2008
    Peoria, IL
    just put in a new upstream 02 sensor and the harness. it threw the p0420 code after my header install, and i also just put on an o2 emulator.
    so why's it still saying p0420? is there a cycle time for reset, or should it already identify the o2 sensor and emulator and eliminate the ses light?
    it's only been 30 minutes and i disconnected the battery to reset everything but it's still on.
  2. #2 Re: ses light cycle time?
    Apr 2009
    stockton ca
    pull your bat for 10 min it will clear the code if it comes back your gonna need to figure out another solution
  3. #3 Re: ses light cycle time?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    splark plug extender on the rear 02 FTW
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #4 Re: ses light cycle time?
    Donating Users
    South Deerfield, MA
    Read this:
    http://www.grandprixforums.net/remov...know-7092.html
    Your 02 GTP will run a catalyst efficiency test. With an O2 emulator, there will not be the proper response from the O2 when the test is run so it will throw the code. You need to have the rear O2 sensor plugged in and set to not report with a tuner.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  5. #5 Re: ses light cycle time?
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    do u have any leaks in the headers?
  6. #6 Re: ses light cycle time?
    Oct 2008
    Peoria, IL
    it went off a few minutes after the next drive i took. should have jus been patient. guessing there is a cycle time cuz after installing headers the p0420 did show for about the same time it took to turn off.
    thanks for the speedy replies!
  1. long time visitor first time poster
    By max98 in forum Introductions/Noob Questions
    Last Post: 05-20-2010, 10:50 PM
  2. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  3. Automatic Locks cycle repeatedly!!
    By illinimd in forum General Tech Discussion
    Last Post: 10-24-2009, 05:46 PM
  4. 121% Injector duty cycle with stock car
    By DanGTP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-27-2008, 08:20 PM
  5. Injectors, what is the max duty cycle?
    By Stonewall in forum PCM Tuning
    Last Post: 03-16-2008, 09:49 AM
