Thread: removing exhaust tips
Results 1 to 8 of 8
  1. #1 removing exhaust tips
    GTX Level Member Bakerdd's Avatar
    Raleigh, NC
    so i was trying to remove my exhaust tips this afternoon and i read somewhere that i just need to loosen the clamp and beat on them with a mallet. I also heard that there may be some welds on the sides? anyway, i got the tip loose and i was able to turn it maybe 45 degrees each direction, so i think i took care of the welds, but i still could not get it off, it was wiggling back and forth, but wouldn't come out. am i missing something?
  2. #2 Re: removing exhaust tips
    no, youre not missing anything. they just get stuck like that for no freakin reason. my suggestion: heat and/or bigger muscles.
  3. #3 Re: removing exhaust tips
    Raleigh, NC
    alright thanks, i'll try again tomorrow
  4. #4 Re: removing exhaust tips
    PB blaster?
  5. #5 Re: removing exhaust tips
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    wheaties
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  6. #6 Re: removing exhaust tips
    Wooster, Ohio
    get some heat around the pipe section to the tip only, hit with large mallet, if that doesn't work hit harder and get hotter, if that doesn't work get bigger hammer, if still not off... get sawzall, cut pipes, get new tips.
  7. #7 Re: removing exhaust tips
    tj
    i did it very easy with the mufflers out of the car , but in your case if its still hanging there , use your legs and push the tips left , right , up ,down then you just pull it out ..
  8. #8 Re: removing exhaust tips
    Charles City, IA
    If you are getting new ones. You could just cut into the tip with a torch or grinder making two slits, one on each side that run parallel to the ground and that will allow the tip to bend and become bigger.
    SMGPFC Two Nipple General
  1. Tips for removing rack and pinion
    By Doerr in forum General Tech Discussion
    Last Post: 12-24-2009, 12:35 AM
  2. Tips on removing excess RTV?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 08-21-2008, 10:25 PM
  3. Tips on Removing Brake Lines
    By JoshMcMadMac in forum Brakes/Suspension/Chassis
    Last Post: 08-16-2008, 08:45 AM
  4. Exhaust Tips
    By SlowPurpleGTP in forum Visual/Body Modifications
    Last Post: 05-16-2008, 08:34 AM
