Thread: 02 GP Shakes upon accelerating
Results 1 to 17 of 17
  1. #1 02 GP Shakes upon accelerating
    SE Level Member riddell87's Avatar
    Ontario
    Hey, i've got an 02 grand prix gt and have had some problems. Lately when i accelerate the car shakes furiously but can be bypassed by either having a very slow start or hit the gas harder(lol), and is even worse when it comes to getting on the highway or trying to pass. If you just let it keep shaking the engine light comes on and blinks and will sometimes stay on or just turn off. I had it scanned and it came up with several miss fires. I replaced the plugs and ignition coils and it did not solve the problem. There was some other vibrating while driving but replacing a bearing and arm fixed that problem. This feels like its more to do with engine/electrical. Has anyone else had this problem? Any help would be much appreciated, thanks.
  2. #2 Re: 02 GP Shakes upon accelerating
  3. #3 Re: 02 GP Shakes upon accelerating
    Charles City, IA
    its an axle.
    axle wont set a miss fire code. Check fuel pressure and injectors. You replaced the wires when you did plugs and coils right.
    SMGPFC Two Nipple General
  4. #4 Re: 02 GP Shakes upon accelerating
    GTX Level Member cerick08GP's Avatar
    So are you still popping codes? If you are still misfiring I would check the spark plug wires. Also, if you still have your coils keep them. They are probably better than the replacements you got. Or better yet, put them back on and try to return the new coils. Anyway a shaking car tends to be a mechanical thing, but that contradicts the misfires. Change/check the wires and have it scanned and get back to us.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  5. #5 Re: 02 GP Shakes upon accelerating
    Ontario
    i haven't changed the wires but that'll definitely be the next thing i check out seeing as its an easy one. i have yet to scan it since i put the new coils in(tonight) but when i changed the plugs a week back it still miss fired. I'll check back soon hopefully with the answer to the problem, Thanks!
  6. #6 Re: 02 GP Shakes upon accelerating
    SE Level Member corvetteii's Avatar
    Jul 2008
    Muncie, IN
    if you let off the accelerator while driving, does it stop shaking? If it mainly shakes during acceleration its most likely an axle/cv joint. I just replaced these on a 98 GTP that was shaking upon acceleration and fixed it.
  7. #7 Re: 02 GP Shakes upon accelerating
    Ontario
    yeah the shaking will stop if i let off the gas. It'll mainly do it if i need to accelerate quickly or trying to accelerate on a incline. whats an axle job like, pricey?
  8. #8 Re: 02 GP Shakes upon accelerating
    i dont think the misfires have anything to do with the vibration.
  9. #9 Re: 02 GP Shakes upon accelerating
    Jul 2008
    Muncie, IN
    Quote Originally Posted by riddell87 View Post
    well each axle is around 70 bucks. Then you need to rent a FWD axle puller and a slide hammer from autozone to pop the axles out of the transmission. You get all the money back when you take the tools back. The job is really not that hard.
    *jack up the car, take the tire off.
    *remove the 33mm (you need a deep well socket) hub nut that holds the axle in the hub.
    *remove the two nuts at the bottom of the strut and slide the bolts out.
    *then take the axle out of the hub and use the puller to pop out of the transmission.
    *be careful when putting the new axle in to not damage the axle output seal.
    When its all back together ensure that there are no transmission fluid leaks at the axle seals ( Start car and drive around the driveway or something).
    This job will cost at least $300-450 if you take it somewhere or $150 DIY.
  10. #10 Re: 02 GP Shakes upon accelerating
    Jul 2008
    Muncie, IN
    I forgot to mention, this GP that i changed the axles on did set off an engine code due to the vibration. Just disconnect your battery and then turn on your headlights for 10 minutes. The object is to remove any residual voltage from the ECM and it will turn off the code. If the code comes back later, then you know you have a problem.
  11. #11 Re: 02 GP Shakes upon accelerating
    Ontario
    Thanks corvetteii, i'll check it out.
  12. #12 Re: 02 GP Shakes upon accelerating
    Ontario
    well fixing that will be put on hold for a bit, got smoked on December 11th by someone who thought it was okay to pull out in the far lane without looking, maybe the shop will fix it thinking it happened in the accident haha
  13. #13 Re: 02 GP Shakes upon accelerating
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    if he is pulling a BLINKING SES light while this vibration happens, I seriously doubt the problem in in suspension. The only thing that will trigger a blinking SES light is a serious misfire in the engine. I understand where everyone is coming from but I doubt axles are your problem. make sure all your wires are going to the right plugs, clean the contacts on each ignition coil, maybe even replace the coils, it's not a bad idea.
    For all your 3800 needs:
  14. #14 Re: 02 GP Shakes upon accelerating
    PA
    Quote Originally Posted by corvetteii View Post
    Wow, lots of interesting advice in this thread. Too bad I just found it now.
    First off, the mis-fires are the most likely reason for the vibration. A misfiring engine is not going to run smoothly. It will shake, and rattle and carry on under acceleration. It is not going to run or drive smooth. And the fact that the OP showed a flashing SES light, which means multiple misfires, and even pulled codes to back that up should point directly to the misfires causing the vibration. If they are bad enough to set the SES to blink, they are more than bad enough to cause a vibration like described.
    As for the axles setting off an engine code for vibration. I would really like to see this happen and know what code it set off. Because I can't think for the life of me how this can happen.
    To the OP, I would like to apologize on behalf of the members in this thread that have led you astray. If/when you get your car back, check the firing order of the plugs and wires to make sure everything is correct. Have the cat checked to make sure it isn't plugged. And check fuel pressure and your injectors on the cylinders that are showing the misfires.
    2001 GSE
  15. #15 Re: 02 GP Shakes upon accelerating
    Ontario
    Just got the report back from the collision center and they scanned to see what the problem was cause they felt it when they test drove it and now its reading a cylinder miss fire i forget what one but they said the plugs, coils an wires are fine, and we had replaced the cat a month ago. they didn't fix it cause they went along with it didn't happen in the accident ha. oh well, it was shy of $1000 from getting written off, so close! hopefully cylinder jobs/this one wont get too pricey.
    Thanks for all the help.
  16. #16 Re: 02 GP Shakes upon accelerating
    Orange County, NY
    I would change out the wires and plugs regardless of what the shop says. It is a cheap ticket and is required in regular maintenance anyway! If you still have the problem then just get one new coil pack...swap them out one at a time with the new one until you either find the problem...or nothing is changed. That way you're only out the price of one new coil pack instead of three!
  17. #17 Re: 02 GP Shakes upon accelerating
    Ontario
    Problem solved! haha, i had changed the plugs and all the coils already and skipped maybe one of the easiest jobs, the wires. One of the wires was pooched and was mucking up everything. Thanks to all who posted, specially the ones who suggested the wires. It's now for sale, check it out or if you know anyone looking for a good deal on a car, drop me an email.
    2002 Pontiac Grand Prix GT Sedan - Guelph cars Cars For Sale - Kijiji Guelph
  1. bad vibration while accelerating help please!!!
    By 01RedfireGT in forum Brakes/Suspension/Chassis
    Last Post: 09-29-2012, 08:54 PM
  2. Weird Whine When Accelerating
    By angelamarie990 in forum General Tech Discussion
    Last Post: 04-08-2009, 10:30 PM
  3. Sloshing sound while accelerating
    By Quicksilver_GP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2009, 07:45 PM
  4. 01 GTP. Car shakes when in Neutral and Park.
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2008, 03:00 AM
  5. Car shakes after lowering
    By Smokedgtp in forum Brakes/Suspension/Chassis
    Last Post: 04-30-2008, 09:17 PM
