2004 Grand Prix Window Problems
bpencak
The other day i was driving and went to roll down all my windows and about halfway down they all stopped working at the same time, and wouldnt go back up right away. They did go up after like 30 min, and then the next day they stopped working when they where all the way down, and it took like 2 hours for them to work again. Did anyone have this problem or know someone who did?
could be the master window switch is crapping out.
do any of the other door window switches work when the master acts up?
when my master switch took a dump none of the other windows has control either.
or in your case it could be a worn through wire in the door between the door and car body. seen that happen a time or two here.
Alright thanks,
Do you think it could be the relay or something too? Or would the other windows still work if it was that?
relays either work or dont work. why the broken wire makes sense.
my child lock switch was crapping out on mine. took the rest of the windows with it. main power starts at the drivers door, if power or the switch is bad the rest crap out too.
