What should the battery voltage be across battery terminals when the car is off? I just checked mine today and it came up 12.10v, which seems low, but it is only10 degrees out... was just reading that at 100% charge it should be around 12.66v..
Time to put a charger on it and charge it before the cold takes it all the way out? the battery is only 2yrs old, just a standard autocraft 700 CCA battery
Only checked this because I got a "charging system failure" message on the DIC the other day... but it hasn't came back and when running the battery voltage on the DIC says 13.9 to 14.5v when driving
