NotEnoughGPs
Member
I am in the process of flushing coolant in a 3.8L NA GP, getting rid of the orange dex-cool and changing over to long life green coolant. I have preformed this process in the past in other 3800's with no issues. To be sure all the original dexcool is out of the cooling system, I use the Prestone Super radiator flush and then I drain the system and put in plain water, drive , drain, repeat, etc.
I started this process and now the air temperature has dropped down to zero (I love PA)
How long would I be able to park the car outside before the water freezes and cracks the radiator and block and causes other issues?
I need to drive tonight (about 35 miles) and shut off the engine and leave the car for about 2 1/2 hours.
Would I be safe doing so?
How long before water will freeze?
After the trip, I will be bringing the car home and parking it in a heated garage, so freeze up will not be an issue then.
Probably tomorrow, I will drain the water out of the car and put in new long life coolant.
Tell me if you think this is ill advised.
