Thread: Suspension Clunking Noises going over expansion joints and moderate bumps
Results 1 to 11 of 11
  1. #1 Suspension Clunking Noises going over expansion joints and moderate bumps
    SE Level Member Crispykit's Avatar
    Apr 2013
    Canada
    I am having some clunking noises going over moderate cracks in the pavement. The suspension is mostly new in the front and tight in the back. The car is a 2001 Grand Prix GT with stock shocks springs. The front has new GMPP Sway Bar, all new ball joints, new axles, Mevotech Sway Bar Links-Poly bushings, new Brembo Rotors and Premium No-Dust pads, Shock tower brace and new lower control arms. The rear has the GMPP sway Bar, Mevotech links, UMI Trailing Arms and shock tower brace. I have put the car on jack stands and can't see any thing that is loose even when banging around with a rubber mallet. I don't know how to replicate the noise when the car is in the air and don't know anything else to try. Any direction or suggestion would be helpful.
    Crispykit 2001 GP GT
  2. #2 Re: Suspension Clunking Noises going over expansion joints and moderate bumps
    How's your motor and trans mounts?
    04 Comp G.
  3. #3 Re: Suspension Clunking Noises going over expansion joints and moderate bumps
    strut mounts can clunk, so can cheap sway bar bushings. my dorman bushings are shot to hell after only a year and maybe 6,000 miles.
    and ball joints. did you just change the ball joints? or the whole lower control arm, cause they can clunk too.
  4. #4 Re: Suspension Clunking Noises going over expansion joints and moderate bumps
    Apr 2013
    Canada
    Thanks for the replies (first thread I have posted since I didn't know a "Thread" is the same as a "Question" ).
    The transmission mounts look OK and I just had the engine lifted to replace the oil pan and the garage did an inspection so I think they are OK.
    I had new control arms installed and they have the ball joints in them, I should have said new outer tie rod ends were done in the front.
    The first things I checked were the sway bar bushings but the Mevotech Sway Bar Links with Poly bushings are in good shape and tight front and back.
    When I tried to remove the old sway bar links in the front the shaft broke and seized in the hole.
    I had to drive to the mechanic with it and I know what that clunk sounded like (mine is not that consistent).
    The noise seems to be coming more from the rear than the front, so I'll try and concentrate on the back (it also has the least new parts).
    Is there a good way to check the Strut mounts? They feel good when I shake them with the wheels off the ground?
    The tops are kind of hard to see from inside the trunk but I could possibly get a torque wrench on the mounts and check that (I have that spec as 33 lb ft)
    Might even test a few of the others if I get the use of a hoist (I'm looking to rent one by the hour from a guy who is making an electric car as a hobby).
  5. #5 Re: Suspension Clunking Noises going over expansion joints and moderate bumps
    May 2013
    Upstate NY
    Blown strut will clunk too. If the bushing around the shaft is gone. Would be kinda easy to see tho (oil everywhere on strut and excessive camber)
    04 CompG, black HAI, 180*, TR55s, custom tune by me, SD headers soon
    04 CompG, fusion orange, all stock
    99 GTP, red, coupe, 3.4, SLP exhaust, basic mods, PB 13.56, SOLD in 09.
  6. #6 Re: Suspension Clunking Noises going over expansion joints and moderate bumps
    heres a thought, check your exhaust system mounts, my mounts broke by the cat and the rear mount broke off and my add a hanger turned and got loose and it was causing a lot of clunky sounds when going over a bumpy road, fixed all that and the car sounds much better.
  7. #7 Re: Suspension Clunking Noises going over expansion joints and moderate bumps
    Donating Users jmak gtx2's Avatar
    Mableton, GA 30126
    Check the rear lower control arms with the car on the ground to see if there is any movement in them. If the car is raised any amount it will put these under load and they will not seem to be lose.
  8. #8 Re: Suspension Clunking Noises going over expansion joints and moderate bumps
    Apr 2013
    Canada
    On the rear I have Spindles, Trailing arms, Stabilizer bar, links, strut mounts but no controlling arms. Which parts are best to test on the ground? I had the car on the hoist and everything was tight. Still have to check the Strut mounts to Body nuts and the Strut Shaft Nut (my towers have a rubber dome on top that's not easily removed (is this a stock item?) so I can't get to them.
  9. #9 Re: Suspension Clunking Noises going over expansion joints and moderate bumps
    Mableton, GA 30126
    Trailing arms are called LCR's
  10. #10 Re: Suspension Clunking Noises going over expansion joints and moderate bumps
    Apr 2013
    Canada
    Well the culprit was the spare tire was loose. I remembered reading in one of the forums to check the spare. I was checking the Strut Mount to body bolt nuts and had cleaned out all the stuff in the trunk. They were tight and I remembered the forum comment and pulled the cover and sure enough it was loose. Boy you just never know (I wonder what a shop would have charged me to find this). Thanks to everyone for your help.
  11. #11 Re: Suspension Clunking Noises going over expansion joints and moderate bumps
    Jul 2013
    ohio
    i have a 04 gp and was making the same noise even over small bumps... i tightened up the bar/bracket leading from the strut tower to the radiator housing. solved my problem...
  1. RPM's jumping around during moderate accel
    By DeNoZZo in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-09-2012, 03:32 AM
  2. Clunking noise over bumps
    By Amb4 in forum Brakes/Suspension/Chassis
    Last Post: 08-04-2010, 08:26 PM
  3. Suspension clunking....please help
    By watters32 in forum Brakes/Suspension/Chassis
    Last Post: 04-28-2010, 10:23 AM
  4. first gear slips/shudders under moderate acceleration
    By almighty in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-16-2010, 04:44 PM
  5. 08 Suspension- Holy Noises Batman
    By BuyMyWheels in forum Brakes/Suspension/Chassis
    Last Post: 11-21-2009, 11:07 AM
