Thread: Any Benefit To Using Heavier Oil?
Results 1 to 10 of 10
  1. #1 Any Benefit To Using Heavier Oil?
    Former GP Owner Chadgervais's Avatar
    Sep 2012
    Bangor, ME
    Hi,
    My 04 GT2 is 221,000 miles young. The engine is strong, never been abused, raced, or anything like that. I have a minor pan gasket leak, I lose a quart about every 3000 miles. The only real "issue" with this car (unrelated at that) is a valve in the fuel line which allows fuel to drain back to the tank when left for a period of time. I have to prime it a couple times before starting.
    My question is, would there be any benefit to switching to 10w30? I know of many GM owners who go from 5w30 to 10w30 as their engine ages, Ive known a few who go to straight 30W. Its had 5w30 its whole life, should I mess with success?
    Thanks.
    FORMER GRAND PRIX OWNER- NO LONGER ACTIVE ON GRANPRIXFORUMS.NET
    YOU MAY PM ME WITH QUESTIONS, WILL ANSWER TO THE BEST OF MY ABILITY
    FORMER RIDE: 2004 GT2, TRADED WITH 244,338 MILES. CURRENT: 2012 DODGE AVENGER
    GOD BLESS...
  2. #2 Re: Any Benefit To Using Heavier Oil?
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    I switched to 10W30 the day I got my grand prix. Heavier oil will reduce some valve train noise and can sometimes help slow oil leaks due to it being "thicker".
    however, if your going to keep the car for awhile id suggest getting the gasket replaced.
    1998 GP Daytona - PLOG, 104's, PRJ Wires, Lucas 42.5's, DHP 1.0 Tune, DP, Full Borla, GPO's, Roof Rails, Gen 2 Spoiler, 04+ Needles, Menards Intake, 3.5 Pulley, SSC Springs, Corn-fed
    2000 Bonneville SSEI - 212k+, New Gaskets and Stuffs
  3. #3 Re: Any Benefit To Using Heavier Oil?
    SE Level Member volvo92906's Avatar
    Nov 2012
    Ohio
    I use 10w-30. It will be a bit thicker when cold, but it wont hurt anything and as stated above, will help with some engine noise as well as slow leaks.
    ASE Master Medium Heavy Truck
    ASE Master Automotive
  4. #4 Re: Any Benefit To Using Heavier Oil?
    This has been covered more times than I can count.
    10w30 is thicker when cold and can cause more wear on the engine in really cold weather.
    Both 5w and 10w30 are the same once fully warmed up.
    Jan 2009
    Tallahassee, FL
    I've always used 10W30.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  6. #6 Re: Any Benefit To Using Heavier Oil?
    GTP Level Member
    springfield IL
    So running a 5w30 oil in winter time be beneficial....??
  7. #7 Re: Any Benefit To Using Heavier Oil?
    Yes... however for all the info behind it. I recommend everyone reads up on bobistheoilguy.com then you'll know way more about oil than you ever needed to know.
  8. #8 Re: Any Benefit To Using Heavier Oil?
    GTX Level Member cerick08GP's Avatar
    Quote Originally Posted by tc300 View Post
    Yes, there is a real benefit. It will reduce wear on start up all year round not just when it is cold. That is why GM went away from recommending 10W-30 to 5W-30 for the newer GPs. In fact my owners manual even says to use 0W-30 (in my own words) for arctic conditions.
    Like Bill said, BITOG is a good resource. The site even has a motor oil 101 class you can access off the home page which is very interesting.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  9. #9 Re: Any Benefit To Using Heavier Oil?
    GTP Level Member
    springfield IL
    Quote Originally Posted by cerick08GP View Post
    Yes I have noticed the newer GM stuff has went to 5w.... I also get up in the early am's for work so I think by the end of the month I will be running 5w for the winter!!!! Car is 00 GT 134,xxx miles.
  10. #10 Re: Any Benefit To Using Heavier Oil?
    GTP Level Member
    springfield IL
    I have sent my oil to Blackstone once a year for the past 3 or 4 years, everything has come back fine.... It has gotten better since I've been using Wix filters to.
  1. MN: cruise in/cancer benefit June 2nd
    By blackbeauty89 in forum Midwest
    Last Post: 05-28-2012, 08:13 PM
  2. Cam or I/C which would be the best benefit
    By Cobras 98 Prix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-20-2011, 09:20 AM
  3. Would I benefit from a 3" exhaust
    By BlackandSilverGTP in forum General Tech Discussion
    Last Post: 03-24-2010, 01:24 PM
  4. Which would benefit me more......
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-23-2009, 07:16 PM
