Thread: New custom lower motor mount design, NO MORE DOGBONES!
Results 1 to 13 of 13
  1. #1 New custom lower motor mount design, NO MORE DOGBONES!
    Reno, NV / San Jose, CA
    For a several years now, I have revised, redesigned, and played with this idea of a lower motor mount that completely eliminates the upper dog bones. Part of the engine vibration issues we feel in the cabin are due to the motor being supported by the front unibody framing above the radiator that directly transmits vibrations to the passenger cabin. Ive wanted a stiff and non moving engine, without the rattles and issues that usually accompany it. I know that cars that do not have the upper arms tend to not transmit these vibrations. However, short of crazy cradle changes, sometimes even the transmission casing itself, there was no easy solution.
    Behold, the solution:
    Mod Writeups by Ryan Cape | Photobucket
    http://i51.photobucket.com/albums/f3...psxqx8puit.jpg
    http://i51.photobucket.com/albums/f3...pstnzxynlt.jpg
    http://i51.photobucket.com/albums/f3...psr59zefok.jpg
    http://i51.photobucket.com/albums/f3...pspwwch2ze.jpg
    http://i51.photobucket.com/albums/f3...psenfjkeen.jpg
    http://i51.photobucket.com/albums/f3...pskbfu1ib6.jpg
    This is a 1/2 inch thick aluminum plate, cut and shaped to follow the contours of the transmission. The tube at the bottom holds one of the original dogbone arm bushings. The angle brackets are also 5056 T6 aluminum. A steel plate with nuts are tack welded on, and slid inside the passage of the aluminum cradle for support. On a steel cradle car, you can tap and bolt directly in.
    NO engine movement, but also still completely rubber isolated. There were previous versions of this mount, but they relied on just a single bolt hole, no rubber mount or isolation to prevent false knock readings, and were too harsh.
    I am considering making more, making kits that can be installed in a few hours. Hardest part is lining it all up and drilling the holes in the cradle.
    www.facebook.com/WestCoastPontiacs/
    97 GTP Sedan 97 GT Coupe 07 Yukon Denali XL
  2. #2 Re: New custom lower motor mount design, NO MORE DOGBONES!
    thats a cool mount you made.
    any thoughts of making steel based ones for the steel frames? those would be way easier to weld on.
  3. #3 Re: New custom lower motor mount design, NO MORE DOGBONES!
    Kemmerer, Wyoming
    looks good
  4. #4 Re: New custom lower motor mount design, NO MORE DOGBONES!
    I can, if there are people interested. Really all that would need to change would be the lower brackets would be steel instead. The rest can stay the same. I considered making it all out of steel, but I was trying to keep weight down and not void out the savings of going to the aluminum cradle.
    The engine doesnt move but a mm or so. just what flex all the mounts give. I did a urethane fill to brand new motor and trans mounts too at the same time. Those have little to no give in then as well. Softer than ZZP poly mounts, but much stiffer than standard.
  5. #5 Re: New custom lower motor mount design, NO MORE DOGBONES!
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    I'm totally in if you design something for steel frames! I'm going to be swapping a 3800 in my fiero, and I don't want to have to shell out for swapping the alternator relocation and loose the option of power steering just so that I can have an upper dogbone mount. This would be a lifesaver! The mount should work with the fiero subframe as well if welded on. Looking forward to seeing how this turns out!
  6. #6 Re: New custom lower motor mount design, NO MORE DOGBONES!
    This reminds me of the H body design. I've seen a few different versions of this idea and overall, I always liked it.
  7. #7 Re: New custom lower motor mount design, NO MORE DOGBONES!
    Quote Originally Posted by wstefan20 View Post
    I can, and I actually have a 3800 swapped fiero here.
  8. #8 Re: New custom lower motor mount design, NO MORE DOGBONES!
    Yea, IIRC "Janice" was her screen name, she had the original variation. About 8 years ago I purchased the templates and all remaining stock from (insert longtime member in community i cant remember who took over the project) and have been revising it since.
    Problem I had with all the previous variations was there was no isolation, it was all metal to metal with the brackets and a bolt, sandwiched. This version has the ability to even upgrade to poly, since there are poly dogbone inserts available.
    ClubGP Message Forum troubleshooting
    the original thread of its first iteration. Some other cool stuff in there too!
  9. #9 Re: New custom lower motor mount design, NO MORE DOGBONES!
    Aug 2017
    Raytown, MO
    Quote Originally Posted by grandprixfamily View Post
    Ohhhhh... I hope you have a build thread on it! I'm definitely going to need some help come this summer on the build. Do you do your own mounts too?
  10. #10 Re: New custom lower motor mount design, NO MORE DOGBONES!
    We got some mounts from west coast fieros IIRC. it was built about 10 years ago. we integrated the full obd2, pcm, and original dash in factory locations and wiring points, so if you dont pop the rear hood, it all looks stock. even managed to keep the factory manual shifter and it just moves back and forth for the auto now. Whole thing drops out using all the factory bulkhead wiring connectors. it was fun to build. Hardest part was wiring it all, wire by wire, running each one how we wanted, and to each pin in the PCM at the factory location.
    itll pull the tires off the ground on the street across an intersection. scary little plastic car.
  11. #11 Re: New custom lower motor mount design, NO MORE DOGBONES!
    Aug 2017
    Raytown, MO
    haha can't wait! I think I'll make it a long term build. I'm ammassing the parts for a forged internal turbo setup with hand ported heads. Definitely a ways off. Can't wait to see how this mount comes out though! Definitely would free up room for other stuff!
  12. #12 Re: New custom lower motor mount design, NO MORE DOGBONES!
    Jul 2010
    Coquitlam,BC,Canada
    Very cool.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  13. #13 Re: New custom lower motor mount design, NO MORE DOGBONES!
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Slick.
    GPONA #1 Cyber Bully
  1. How to change lower motor mount and trans mount
    By AlanP in forum How To Write-Ups/Tech Tips
    Last Post: 01-10-2021, 12:39 AM
  2. Need some help on Lower Motor Mount
    By Burbman in forum General Tech Discussion
    Last Post: 11-16-2012, 09:29 AM
  3. '98 3.1L lower motor mount, tranny mount replacement help
    By Patrick551 in forum General Tech Discussion
    Last Post: 10-07-2012, 11:37 PM
  4. Lower motor mount...
    By Iceman6669 in forum Brakes/Suspension/Chassis
    Last Post: 04-27-2012, 02:23 PM
  5. Stock Torque motor Mount Does not match new one? Different design
    By CheeWee in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2010, 06:46 PM
