Thread: Pontiac Grand Prix LED Conversion Kit! See Installed Pics! Plug & Play Install!
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 98
  1. #61 Re: FS: BRIGHT LED Conversion Kit!!! (upgrade your lights, great easy mod!)
    Pennsylvania
    The bulb is fully installed and the connection is complete, as near as I can tell.
    Popping the trunk without the key in causes the board to output ~10% light, significantly less than the stock bulb. When they key is in, it's light broad daylight in the trunk.
    This is the same case for the vanity mirrors and the glovebox, though I pretty rarely use those without the key in, so they don't bother me.
    It strikes me as some sort of dirty ground issue, but I can't imagine how turning the key changes that without actually starting the car. If I swap the stock bulbs back, they work at full brightness.
  2. #62 Re: FS: BRIGHT LED Conversion Kit!!! (upgrade your lights, great easy mod!)
    Dec 2008
    Lawndale, CA
    Just installed a set in my 99 grand prix and in my brothers 03 grand prix. They look great. We both had slight issues with the trunk light board. It seems that the ground pin on the mini connector seems to pop out once in awhile, causing an intermittent connetion. I was able to remedy a fix to keep the pins intact. Right now they are both working just fine. Other than that they all work and they look great.
    One thing I forgot to mention, is that the vanity mirror LEDs are larger than the factory bulbs. They will pop off when trying to leave the bulb in these on it's own. We had to use the plastic cover to hold them in place. But they look great.
  3. #63 Re: FS: BRIGHT LED Conversion Kit!!! (upgrade your lights, great easy mod!)
    Donating Users Paul J McCain's Avatar
    St. Louis, MO
    It can be a little tricky, but I am glad you got them working!
    Click For All Pontiac Lighting
    Your Experts in Pontiac Lighting
    (314) 205-3033
  4. #64 Re: FS: BRIGHT LED Conversion Kit!!! (upgrade your lights, great easy mod!)
    Dec 2008
    Lawndale, CA
    Paul do you guys offer any type of LED replacement for a 561 rigid loop bulb? This is for the dome light bulb for my 2002 Camaro SS.
  5. #65 Re: FS: BRIGHT LED Conversion Kit!!! (upgrade your lights, great easy mod!)
    St. Louis, MO
    Unfortunately we do not offer any bulbs in that size.
    (314) 205-3033
  6. #66 Re: FS: BRIGHT LED Conversion Kit!!! (upgrade your lights, great easy mod!)
    GT Level Member Cocor's Avatar
    Aug 2012
    Collinsville, il
    Hey Paul. Was just in your store a week ago getting an HID kit for my 05 GXP. I'm looking to upgrade some LED's. I know you carry the 194, 3157, and H11 bulbs I'm gonna get. Just wondering if you have any bulbs to replace a 3057 taillight, 2825 Interior light, and a 4157NA front turn signal?
  7. #67 Re: FS: BRIGHT LED Conversion Kit!!! (upgrade your lights, great easy mod!)
    antioch ill
    is the stage 3 kit for my 2000 and plug and play?
  8. #68 Re: FS: BRIGHT LED Conversion Kit!!! (upgrade your lights, great easy mod!)
    St. Louis, MO
    Yes all our led bulbs are plug and play
    (314) 205-3033
  9. #69 Re: FS: BRIGHT LED Conversion Kit!!! (upgrade your lights, great easy mod!)
    Jun 2011
    Interior kit for an 04+ GP?
  10. #70 Re: FS: BRIGHT LED Conversion Kit!!! (upgrade your lights, great easy mod!)
    Wichita, KS
    Very Nice!
    Currently I have LEDs from "super bright leds dot com". They are "ok". The GF has the same bulbs in her GTP, I recently had to yank the bulbs out of her map lights as they were acting like a strobe light, and sometimes would stay on, have a slight dim light coming out of them at night when they should be off.
    I think were going to be doing a two car upgrade.
    ~F~
  11. #71 Re: FS: BRIGHT LED Conversion Kit!!! (upgrade your lights, great easy mod!)
    St. Louis, MO
    Quote Originally Posted by GR8racingfool View Post
    Very Nice!
    ~F~
    The flickering is a sign of premature failure, normally caused by heat.
    (314) 205-3033
    I live here. DirtDog's Avatar
    Jun 2012
    Are u gonna be running any holiday specials
    Sent from my pager using Morse code. ... .. ... ....
  13. #73 Re: FS: BRIGHT LED Conversion Kit!!! (upgrade your lights, great easy mod!)
    SE Level Member BigKev2403's Avatar
    Feb 2013
    Cleveland Ohio
    I am interested in getting a kit from you, however there is one particular light that I'm having trouble finding. Your kit is very extensive, but I am wondering which bulb would I be looking for for under the dash, in the foot area? Does your kit already include it and I'm just missing it? Thanks in advance...
  14. #74 Re: FS: BRIGHT LED Conversion Kit!!! (upgrade your lights, great easy mod!)
    St. Louis, MO
    Quote Originally Posted by BigKev2403 View Post
    Unfortunately I don't have that particular bulb referenced. But if you take a picture of the bulb, I may be able to help you out.
    (314) 205-3033
    St. Louis, MO
    RGB Footwell and Grille Lighting Kit shown on our 2016 F-150 SEMA Build
    (314) 205-3033
    St. Louis, MO
    Modern looks, plug and play installation!
    (314) 205-3033
    St. Louis, MO
    PM responses sent!
    (314) 205-3033
    St. Louis, MO
    PM Responses sent!
    (314) 205-3033
    St. Louis, MO
    Don't forget to send us a PM for the free-shipping code!
    (U.S. members only)
    Thank you,
    Nick C.
    (314) 205-3033
    St. Louis, MO
    Questions? Chat with a live representative on our site!
    Diode Dynamics Website
    (314) 205-3033
  1. Headlight bulbs? Whats the best/ most bright?
    By 87GN97GTP in forum Visual/Body Modifications
    Last Post: 01-21-2010, 07:32 PM
  2. easy kill
    By vailskier3 in forum Track Sessions and Kills
    Last Post: 01-18-2009, 09:31 AM
  3. Easy Kill Right?
    By GTPJOE90 in forum Track Sessions and Kills
    Last Post: 06-02-2008, 11:19 PM
  4. That was easy...
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-26-2008, 11:47 AM
