Abs sensor harness
grazin
Hey guys, it seems like once a month I'm fixing something g on my 2003 gtp..
I was getting the abs and Trac off lights very randomly for a while and I got progressively worse..
Now it comes on shortly after I put it in gear and drive..
Is it most likely one of the harnesses that's causing this..
I'm getting ready to order the dorman repair harnesses. . What say you guys?
Sent from my SM-G900V using Tapatalk
I'd inspect the harness before you buy a new one. They like to corrode and/or break right near where they attach to the LCA right before they plug into the hub.
Yea , that's the part of the harness I'm looking to buy..
I'm not going to replace the whole thing.. and instead of just trying to repair just the break , I feel better getting the new lower harness. .
Hey thanks for your help...
The new harness will need to be spliced in near the subframe inboard of the lower control arm. The only plug is where it connects to the hub. Therefore if you check the harness you may find the damage could be cut out and spliced back together. Otherwise, I have picked up a harness from the junk yard for like $2 and it has been working fine for over a year. When my ABS was acting up it happened when I was turning and going over a bump, that's when the harness was bent and jostled the most.
