Double checking sway bushings
SomeDudeAtHome
I just want to double check I have everything needed to install some sway bars I just ordered. I don't want to get half way through and realize I'm missing something.
2x bushings for the front
2x endlinks for the front
2x endlinks for the rear (moog K6662) correct?
2x bushings for the rear? Not sure if I need these for the rear or only the front.
If I'm missing anything please let me know. Thanks.
Yes there is a set of bushings and endlinks in both front and rear. On the bushings.. typically they come as a set. Often endlinks come individually.
awesome thanks. I was able to spot them on the front bar but couldn't get my head under far enough for the rear.
Is the rear endlink correct? Not sure if that's right or if I need something simliar to the front.
