Thread: Symptoms of bad lower tranny/engine mounts
Results 1 to 7 of 7
  1. #1 Symptoms of bad lower tranny/engine mounts
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    Is there any sure sign of when the lower mounts go bad. I have AGX's and B&G's. It's more prominent on the driver side but when I do a slow roll over a crack in the road/pavement it's not quite a clunk, but not a smooth rollover either.
    I know the mounts are hydralic, the struts are about 8 months old, 5000 miles, so any insite would be appreciated. Everything suspension wise was replaced when I did the makeover (swaybar included).
  2. #2 Re: Symptoms of bad lower tranny/engine mounts
    Nov 2009
    Grand haven
    How about a lower ball joint?
  3. #3 Re: Symptoms of bad lower tranny/engine mounts
    Apr 2009
    Carlisle PA
    Quote Originally Posted by shawngtp View Post
    Put in brand new lower control arms when I did the struts, springs... All the suspension is brand new (not to say it something couldn't of gone bad). The mounts I didn't touch though and probably factory original (160K).
  4. #4 Re: Symptoms of bad lower tranny/engine mounts
    Donating User Odi's Avatar
    Chicago South Suburbs
    get poly mounts and vinnies spacer. idk why you didnt do that since your car is lowered.
  5. #5 Re: Symptoms of bad lower tranny/engine mounts
    Apr 2009
    Carlisle PA
    Quote Originally Posted by MiriV View Post
    Did the shortened dog bones instead. I already have new mounts I have to put in yet, at that time I'll put in the spacers I already have.
  6. #6 Re: Symptoms of bad lower tranny/engine mounts
    Banned - Busted For Scamming
    Feb 2009
    Check the tightness on the front lca bolts, mainly the torx head front ones. If they are loose you can get a clunk/pop noise.
  7. #7 Re: Symptoms of bad lower tranny/engine mounts
    Donating Users
    South Deerfield, MA
    I was thinking the same thing minichopper said. Double check that first.
    The factory engine mount is hydraulic and collapses if it fails. Look at the dogbones on the front of the engine and see if they look out of alignment. My engine mount was bad and the dog bones were sitting crooked. When I removed the engine mount, there was a lot of oil under it. Replaced it, put it back together and the dog bones were lined up straight.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  1. Motor and tranny mounts....
    By ExpyGator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-15-2010, 09:00 AM
  2. Engine mounts?
    By GAFF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-17-2010, 05:39 PM
  3. Tranny clunks/no lower gears?
    By SDGTP99 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-31-2009, 07:07 PM
  4. engine mounts?
    By elusive racing in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2009, 10:44 PM
  5. motor and tranny mounts?
    By libster in forum Brakes/Suspension/Chassis
    Last Post: 08-03-2008, 10:12 PM
