Thread: Replace Brakes and Rotors But still have a rubbing Noise.
Results 1 to 10 of 10
  1. #1 Replace Brakes and Rotors But still have a rubbing Noise.
    SE Level Member rollin77's Avatar
    Nov 2009
    Jacksonville, fl
    Replaced brakes and rotors. They were squealing but rubbing/grinding. Did that today. I still have the noise after changing the rotors and brake pads. I hear it mainly when I come to a stop, but even after I drive away from a stop I hear it and it continues on.
  2. #2 Re: Replace Brakes and Rotors But still have a rubbing Noise.
    Nov 2009
    Jacksonville, fl
    Anyone?
  3. #3 Re: Replace Brakes and Rotors But still have a rubbing Noise.
    Charles City, IA
    Check the anti rattle clips. By breaks you mean pads or calipers? You could have a sticky caliper. Also Did you lube everything when you put it together?
    SMGPFC Two Nipple General
  4. #4 Re: Replace Brakes and Rotors But still have a rubbing Noise.
    Nov 2009
    Jacksonville, fl
    I replaced the pads, and the rotors. Lubed everything as in the caliper bolts? Yes, what else should have been lubed? One of my friends, friends is a GMAC mechanic, he was in town for the day and helped me do it.
  5. #5 Re: Replace Brakes and Rotors But still have a rubbing Noise.
    Contact points between caliper and pads. Sure its not a bearing?
    Funny story related to this: customer asked me this weekend if there was a lube he could put on his rotors to help with brake noise...
  6. #6 Re: Replace Brakes and Rotors But still have a rubbing Noise.
    GTX Level Member cerick08GP's Avatar
    Well, if you think it is the brakes are still causing the noise I have an idea.
    Be aware the brake cylinder retracts a very small amount after pressure is released, I’m talking about the wheel cylinder just to clarify. If your brake cylinder doesn’t retract, it will make a little noise because the shoes will rub a little against the rotor. But the brakes will still work fine. Re-building the brake cylinder is easy and cheap, it just takes a bit of time.
    This may account for the noise just after stopping, the noise before you stop could simply be your new pads are just more aggressive than your old ones. Just a thought
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  7. #7 Re: Replace Brakes and Rotors But still have a rubbing Noise.
    Quote Originally Posted by cerick08GP View Post
    rebuild kits are becoming more and more difficult to find. Most people just say to hell with it and buy a reman caliper.
  8. #8 Re: Replace Brakes and Rotors But still have a rubbing Noise.
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    ^^ x2, but they are available. I bought a couple for my GXP calipers.
    For all your 3800 needs:
  9. #9 Re: Replace Brakes and Rotors But still have a rubbing Noise.
    Nov 2009
    Jacksonville, fl
    Thanx for the info guys! Hopefully get the problem fixed this weekend.
  10. #10 Re: Replace Brakes and Rotors But still have a rubbing Noise.
    Nov 2009
    Jacksonville, fl
    @matt5112; That's a funny story man!
  1. new back brakes. Hows the summit racing rotors?
    By mxthunder in forum Brakes/Suspension/Chassis
    Last Post: 11-01-2009, 11:15 PM
  2. 'Rubbing' Noise when Backing Up
    By nickbuol in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2009, 10:41 PM
  3. Rubbing noise from front left tire
    By zeppelinrocks18 in forum Brakes/Suspension/Chassis
    Last Post: 10-15-2009, 05:45 PM
  4. Brakes and Rotors
    By streetsmart in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2009, 11:22 PM
  5. Brakes making noise.
    By TDCRacing in forum Brakes/Suspension/Chassis
    Last Post: 07-26-2008, 10:03 AM
