Thread: Service ABS System/Service Traction System lights?
Results 1 to 16 of 16
  1. #1 Service ABS System/Service Traction System lights?
    SE Level Member VicRDE82's Avatar
    Apr 2016
    Dickinson, TX
    Hey guys I recently had these lights both come together the other day and am stumped on what it could be. I checked the speed sensor connections for corrosion on both front wheels, and all looked well. I also did a wheel bearing test with the front end jacked up, driver side was tight and passenger had maybe a 1/8" of play. My question I guess would be does O'Riley or Autozone have a scanner that can pinpoint what/where it can be coming from? Or anyone else have a similar problem that can shed some light on what else to check?
    Appreciate any and all input guys and gals!
  2. #2 Re: Service ABS System/Service Traction System lights?
    you need to pay for that scan at a shop. or find a friend with a tech 2 scanner or a snap on one.
  3. #3 Re: Service ABS System/Service Traction System lights?
    I'm not sure if they have a scanner that will read ABS codes, maybe call them and check.
    It could also be a rear bearing too. And a speed sensor may be bad but the bearing still in good shape alot of the time, which kinda sucks sometimes.
  4. #4 Re: Service ABS System/Service Traction System lights?
    St. Louis
    What year of GP are you driving? A lot of times on the 97-01's (maybe 02's as well, can't remember for sure) the harness that goes from the hub to the main harness is 2 pieces, and the wiring gets "dry wire" and causes an ABS issue. Had it happen on my 00 GP GT. I had to cut back almost 3 inches before I found clean copper. I just replaced the harness at that point but you get the idea.
  5. #5 Re: Service ABS System/Service Traction System lights?
    Apr 2016
    Dickinson, TX
    It's a 06 GT FordMan77, heard of that happening on or around that year?
  6. #6 Re: Service ABS System/Service Traction System lights?
    St. Louis
    Not sure on the newer years to be honest. I know at some point they made the harness from the hub to the main loom all one piece, with just 1 connector at the hub. I would think it could still be possible at the plug end if it gets corroded.
    When I was trying to track mine down I used my multimeter to probe each wheel bearing. Jacked the car up, put the probes into the connector at the hub and spun the tire by hand. If I saw voltage then I knew the signal at the hub was good. Can't remember what setting I used to see the voltage change tho, it's been a while.
  7. #7 Re: Service ABS System/Service Traction System lights?
    Apr 2016
    Dickinson, TX
    Well after hunting around on the forums and doing some research I'm leaning towards a bad EBCM. I have noticed the power steering harder to turn while driving under 30mph. Have a buddy that has a Snap On scanner that does ABS as well going to check it out for me this weekend. Am I able to drive the car while it is pulled? Not sure how long the turnover will be with sending it out to be rebuilt/ Thanks as always.
  8. #8 Re: Service ABS System/Service Traction System lights?
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    It's almost never a bad EBCM, 95% of the time it's a bad hub bearing. First off, there are sensors at all 4 wheels, not just the front. The ABS and traction control both use wheel speed data, so when a sensor goes bad, it turns both lights on. The sensors are inside the hubs, so if the sensor is bad, the fix is to change the hub.
    If you get it scanned you should pull a code that will tell you which bearing is bad. As FordMan said it can be a wiring issue, I just fixed what he describes on my 98.
  9. #9 Re: Service ABS System/Service Traction System lights?
    SE Level Member b4black's Avatar
    Oswego, IL
    Cheap but useful
    http://www.amazon.com/Innova-3030g-D...rds=Innova+abs
    Also, I went to the junk yard and cut off electrical connectors for two hubs. Then I used them (along with some spare wire) to make "jumper cables" so I could plug the right sensor into the left connector and vice-versa. When the ABS codes didn't change, I knew the problem was in the wiring or EBCM, not the wheel bearing.
    2002 Buick Regal GS - Intercooler, TOG headers w/ full 3" exhaust, 60# injectors, K&N cone, MPS 2.9, GMPP sway bars and STBs, 18"GXP wheels, 12" impala rotors, alternator hotwire, fuel pump hotwire, HPTuner newbie, Flex Fuel And 1982 Buick Regal GN & 1996 Dodge Ram Diesel 4x4 & Richard Petty's 43 JR Hemi Barracuda drag car
  10. #10 Re: Service ABS System/Service Traction System lights?
    Oswego, IL
    Quote Originally Posted by FordMan77 View Post
    Could you explain "dry wire" further? I think this might be my problem - I have an '02 and I want to be sure it's the wiring before I start cutting & splicing. Thanks!
  11. #11 Re: Service ABS System/Service Traction System lights?
    dry wire is when air gets to the copper wires and they dull and tarnish, current no longer flows through them properly.
    most of the time this is caused by damaged wire insulation, cracks and or missing insulation will let air to the wire.
  12. #12 Re: Service ABS System/Service Traction System lights?
    Apr 2016
    Dickinson, TX
    Quote Originally Posted by Burbman View Post
    If that is the case how does that explain the tightening of the power steering? Fluid level is good and no noticeable whine from the pump, but the tightness is there.
  13. #13 Re: Service ABS System/Service Traction System lights?
    when the abs light turns on the magna steer cuts out.
  14. #14 Re: Service ABS System/Service Traction System lights?
    Dec 2008
    ****'s Creek
    Power steering is variable assist, also known as Magna Steer. It increases boost at slower speeds to give you more assist when parking, etc, and reduces boost at highway speeds to give you more control. Without data from the wheel speed sensors, it shuts off, just like ABS and Traction control, so that you don't get overboosted steering on the highway, which can make the car difficult to control. So the default is the lowest level of boost, which is why the car feels stiffer than usual at slow speeds and when parking.
    A common problem is the front wheel wiring. If you follow the harness where the wheel speed sensor plugs in, you will see it goes for a few feet up into the engine bay and there is another connector where it joins a larger harness. This is on both front sides. That section of wire goes bad, I had to replace the left side on the 98.
    When your buddy does the scan, you will likely see a code for one of the wheel sensors not reading in range. So then it's either the bearing/sensor itself or the wiring going to that corner.
  15. #15 Re: Service ABS System/Service Traction System lights?
    Apr 2016
    Dickinson, TX
    Okay I can also test these connections with a volt/ohm meter to help pinpoint as well? Would that save me from having to get it scanned, or should I still plan on doing it? Thanks for the responses guys!
  16. #16 Re: Service ABS System/Service Traction System lights?
    Dec 2008
    ****'s Creek
    The hub speed sensor should read between 850-1350 ohms. No continuity means bad sensor.
    Sent from my SM-G930V using Tapatalk
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  1. Replies: 5
    Last Post: 02-01-2017, 09:35 PM
  2. Service ABS/Stability/Traction/Brake System
    By Perma in forum General Grand Prix Discussion
    Last Post: 06-01-2015, 06:38 PM
  3. Service Traction Control and Stabilty System
    By shaneh17 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-19-2015, 10:26 AM
  4. Too much power?! Service traction system light...
    By slimguns in forum General Tech Discussion
    Last Post: 08-18-2014, 08:15 PM
  5. Replies: 14
    Last Post: 09-29-2012, 06:45 AM
