Thread: Power Steering Woes
Results 1 to 3 of 3
  1. #1 Power Steering Woes
    SE Level Member tgarison's Avatar
    Abilene, Tx
    Hey all,
    Recently the power steering on my Grand Prix GT went out I have replaced the power steering pump, the power steering pressure line, and the power steering return line, here is my problem the steering is still very jerky, and there is a serious leak where the pressure line meets up with the screw in fitting. I am wondering could it be something simple like a bad o-ring?
    If you want to find out more about me or my GPGT click the link below it takes you to my youtube channel.
    http://www.youtube.com/user/grandprixgt1999
  2. #2 Re: Power Steering Woes
    there is a small o ring on the end of the lines to the rack.
    or you cross threaded it and its leaking, they can be a pita to thread in squarely some times.
  3. #3 Re: Power Steering Woes
    Abilene, Tx
    I also had the thought that it could be a bad o-ring so I tried replacing it with on that came off the old line because it never leaked from there now it leaks worse then ever! Its pissing out fluid in a steady stream where before it just dripped real slow. With that old o-ring its now leaking from around the threads and from between the line and the fitting. This is so frustrating!!
  1. Replies: 3
    Last Post: 11-26-2014, 08:16 AM
  2. Power steering woes....
    By joshuaandrew92 in forum General Tech Discussion
    Last Post: 07-09-2013, 01:27 PM
  3. Power Steering
    By villanex in forum General Grand Prix Discussion
    Last Post: 11-29-2012, 01:07 AM
  4. power steering. feels like i have "half" the power
    By colindunn in forum General Tech Discussion
    Last Post: 07-23-2011, 09:15 AM
  5. Power steering woes
    By Fiero in forum Brakes/Suspension/Chassis
    Last Post: 02-17-2011, 11:58 AM
