Thread: Valve cover
Results 1 to 7 of 7
  1. #1 Valve cover
    Sep 2011
    Omaha
    Does anyone know where I can buy new OEM valve covers? :2004 gtp:
    My brothers buddy is going to change my vc gaskets. I was going to buy a new set and paint them before he changed the gaskets, so he could just put the new painted VC on. Also when I paint them will I just paint with some duplicolor high heat paint? Clear coat or no? And will I have to bake them in the oven?
    3.5 in" pulley, zzp dp, custom hai, colder plugs, red wires- red means fast, Tog headers, resonater Delete, custom dyno tuned and max out injectors...
  2. #2 Re: Valve cover
    Dealership but why waste the money?Or snag a set from the junkyard. I would just clean yours up and take a few minutes and paint them any paint will basically work. Yes high heat will work.
    04 Comp G.
  3. #3 Re: Valve cover
    Prep is key!
    04 Comp G.
  4. #4 Re: Valve cover
    Sep 2011
    Omaha
    Because the guy that's gonna do them would have to wait after I took them off. Then paint, plus since this is my dd I can still drive it and do it. Will I want to clear coat them? Is there a how to on how to paint them or is it pretty straight forward, tape off gasket area, and bolt area?? Or will that matter? Then spray with high heat paint 5-6 coats?..any brand of paint work better than the other?
  5. #5 Re: Valve cover
    Sep 2011
    Omaha
    Prep is key!
    What would prep consist of? Just spray the s*** out of it with degreaser?
  6. #6 Re: Valve cover
    Quote Originally Posted by Akuch26 View Post
    You know you can do your own valve cover gasket right? It's very simple and requires simple hand tools and doesn't take that long. If you go that route just remove, degrease them and you can sand them light will 800 grit primer (2 coats should be fine) then paint (2-3 coats) then clear (2 coats) of course you can take it a step further and wetsand in between buts that's up to you. The coats you do are also your choice but generally it doesn't take much.
    04 Comp G.
  7. #7 Re: Valve cover
    Dec 2008
    Lawndale, CA
    You could do this on your own in a weekend.
  1. Valve Cover
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2011, 10:24 AM
  2. Valve cover gaskets...
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2009, 06:14 PM
  3. Valve Cover
    By justaV6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 09:15 PM
  4. New valve cover and redone FWI
    By snow99dohc in forum Visual/Body Modifications
    Last Post: 03-15-2008, 02:46 AM
