Thread: Low boost, block off boost bypass solenoid. Full boost returns..
Results 1 to 20 of 31
  1. #1 Low boost, block off boost bypass solenoid. Full boost returns..
    Sep 2011
    Copperas Cove, TEXAS
    Just as the title says, after TONS of reading I could not find the answer, even got a buddy on clupGP running a thread to find the answer and nothing yet.
    Little back story- I have had my 98 GTP since November 2011. Since owning it, the boost has never risen above 3.4lbs. So I started throwing parts at it since I was unsure of what the culprit was. As of now it has
    NEW
    LIM Gaskets
    Upper manifold gasket (between SC and LIM)
    Throttle body gasket
    Injector O rings(Lubed and wiggled in to seat them)
    Vacuum Tree O-ring
    MAF sensor
    TPS
    IAC
    MAP sensor
    Evap solenoid
    BBV (from ZZP)
    BCS (from dealership)
    SC belt
    SC Idler (old shredded to include belt hence new SC belt)
    Acc. Belt
    Cat conv.
    U bend delete
    Cat back (new pipe and mufflers)
    Vacuum hose from TB to BBV to BCS to FPR to Snout to MAP to Tree to EVAP solenoid.
    I have sprayed carb cleaner all around this engine to find NO vacuum leaks. I monitor my vacuum with the Torque app and it reads 20-21 at idle, yes I know a mechanical gauge is more reliable (not in budget right now).
    So I ran across a thread where a wise person told the questioner to remove the vacuum hose between the BCS and FPR and run the hose JUST from the FPR to the snout and then unplug the BCS(electrical connection). READ post number 16 http://www.grandprixforums.net/booooost-68178.html
    So I thought what the hell, why not. I did this and got full boost and so fun to drive now.
    This has me wondering though
    1. Why does this trick work?
    2. What about that NEW BCS? (it's just sitting there now, not bolted to the BBV, the new BBV did not have the tab to bolt it down)
    3. Are there any side affects of doing this?
  2. #2 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    HUDSON
    I found the vent plugged on the BBV solenoid on my car the day I drove it home after buying iy in 09'. It should have a little filter on the end of it, they get clogged with dirt over the miles and years. I removed the garbage and installed a 90 degree angle vacuum elbow on the end of it, cured the problem of not gatting full boost at WOT.
  3. #3 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    Sep 2011
    Quote Originally Posted by QUICKSILVER462 View Post
    I figured that's what happened to my old BCS, so I bought a new BCS from the dealership. Thanks for the reply.
  4. #4 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    did u try unpluging the bbv solenoid the eletric part and see if it goes full boost then it might be the ecm is only letting it go to half boost
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  5. #5 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    Apr 2009
    Elkhart
    LOL nm just seen you did that i would say the ecm is causing it to not go full boost....i dont have it even hooked up on mine i just have the top of it hooked up so it still vents at idle
  6. #6 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    Sep 2011
    Quote Originally Posted by 00grandprixgtp View Post
    Which brings me to my 3 questions and also can a bad ECM cause these types of symptoms?
  7. #7 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    Sep 2011
    Took pictures to show what I did.
    Cap off the "T" were the vacuum hose from the BCS goes to
    Unplug the BCS (electrical connection)
    Let this end of vacuum hose from BCS just sit/ lay there
    No tab for the BCS to bolt onto, came from ZZP that way
    Full picture to include the messed up paint from carb cleaner landing on the snout, not happy about that, but had to do it for possible leaks.
  8. #8 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    1. you have no BBV, it's BCA or BCS.
    2. you don't have to unplug the fpr to bcs, if you unplug the bcs wiring then you have no worries.
  9. #9 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    Sep 2011
    Tracking and will correct the item description, thanks.
  10. #10 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    Sep 2011
    So does the ECM control the BCS?
    Does a new ECM have to be programed/flashed for the specific vehicle or can I mount just any JY ECM?
    Still wondering about the three questions I posted.
  11. #11 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    Sep 2011
    Going to try something, the BCS has nothing to bolt onto. I'm going to make a metal bracket for it to bolt to and then hook it back up to see if that is why it does not work. Also replace fuse 21 to see if that is why it kept blowing. Maybe the BCS has to be grounded? It just eats me up that I have this part not working, even though after unhooking it I got full boost.
  12. #12 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    Sep 2011
    Update to this, I tried bolting down the Boost Control Solenoid, connected the eletricals and nothing. Still only produced 3.3 pounds of boost. So I opened the hood put it back to the disconnected option and back to full boost.
    Some people might be thinking or wondering, "HEY" you got full boost, so why are you concerned about the BCS?
    Well, I just don't like having a $40 part just sitting there doing nothing also I want to learn and understand the reason disconnecting the BCS worked.
    Sums up exactly what I thought after I read the first paragraph lol
    04 Comp G.
  14. #14 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    Sep 2011
    I just want to know WHY, I don't like not knowing. Guess I just have to deal with it huh?
    When in doubt blame Gold Racekar and call it a day
    Or blame GM and that should stop any thoughts as to why lol.
    04 Comp G.
  16. #16 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    Sep 2011
    Maybe I should put the BCS in for sale section
    You should I'm sure someone's always looking for one. It'll find your pre gen search.
    04 Comp G.
  18. #18 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    Sep 2011
    Only thing though, I modified the bracket on it. Oh well I'll leave it there and let people ask me why I have it unplugged LOL.
    Put it in the garage..weight reduction.
    04 Comp G.
  20. #20 Re: Low boost, block off boost bypass solenoid. Full boost returns..
    Sep 2011
    LOL, I'm 336 miles away from my garage.
  1. boost bypass
    By Erik Adam Rodriguez in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-06-2012, 02:06 PM
  2. boost bypass valve solenoid wiring
    By 97RS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2011, 09:59 PM
  3. Boost Bypass mod
    By BADAZGTP in forum General Tech Discussion
    Last Post: 05-30-2008, 11:49 AM
  4. Boost Bypass Mod????
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2008, 11:04 AM
