Thread: First mod decision
Results 1 to 10 of 10
  1. #1 First mod decision
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    Hello everyone. Ive got the following on my CompG:
    180 thermo
    GMPP trailing arms
    custom fenderwall intake w/ K&N drop-in
    What would you guys suggest be for first mod this spring? I'm thinking either a 2.5" downpipe, wizair intake or Overkill PCM.
    I want to do one of these this spring them probably another one later in the summer. What would be the safest route to go? Thanks.
  2. #2 Re: First mod decision
    GrandPrix Junkie FastKatt's Avatar
    Feb 2008
    Rkrd, IL
    Scanner, or Tuner FTW
    Best to know what's happening with your mods right from the start
    If you're going to keep modding, then don't waste $ on a PCM, just to need programing all the time
    HTH
    No trees were destroyed for this message.
    However, a great number of pixels were extremely inconvenienced.
    2004 Grand Prix Comp-G GTP Mod List - MySpace
  3. #3 Re: First mod decision
    SE Level Member TheRealKoop's Avatar
    Lima, Oh
    Id say downpipe, open intake(dont buy a wizair, just make one), then plugs/pcm.
    I wouldnt really worry about a scanner till you add the pcm or try to drop a pulley size. Doing some little supporting mods isnt going to hurt anything.
    97' GTP- HAI| 160| N*| Ported Blower| 2.55"|
    S2 ZZp IC| LIM| Heads| 50#| XP| Pacesetters| Flow40's
    AL 103| S2 Volt Booster| Alt rewire| FP rewire.
    Built Tranny| Poly Mounts| 3.69's| 3000 stall.
    Walbro 255|AEM WB| Powertuner.
  4. #4 Re: First mod decision
    Feb 2008
    Rkrd, IL
    So, you'd tell him to spend $150 on a PCM, to just buy a tuner later for $400 or more?
    Why not put the $150 in a bank and save for the tuner???
    Or, are you saying "No Tuner", and just get a stand alone scanner?
  5. #5 Re: First mod decision
    Feb 2008
    South Bend, IN
    or if i get the downpipe, intake, pcm in that order I can have overkill tune my pcm to those mods? Is that right?
  6. #6 Re: First mod decision
    Feb 2008
    Rkrd, IL
    Kind'a,...
    What about pulley?
    Why not Headers, and not just a DP?
    Plus, a "Box Tune" isn't going to match your car 100%...
    JMHO
  7. #7 Re: First mod decision
    Feb 2008
    South Bend, IN
    ive got the extended warranty on my car. it still has 2 years or 71,000 miles, whichever comes first. right now ive got 28k on the car. I will go for the pulley and the serious mods once that ends. I hate beating on my car and I know if I go towards the serious stuff then im going to start abusing it. i will wait till it gets some miles on it and the warranty ends. Its hard for me to beat on a car that im still making payments on also.
    I mean if I just get 2.5" downpipe, intake, plugs then a "box-tuned" pcm in that order I wont be doing any damage to my car right? and im going to see a good performance improvment?
  8. #8 Re: First mod decision
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by 04CompG View Post
    Understand where you are coming on not wanting to go crazy with modding before the warranty is up... been there, thought I was going to do that.
    If you do a 2.5 or 3" DP, plugs (no need to change these out really), Intake ( don't do the open cone - it's ricey plus there is a lot of good science as to why this makes no sense or HP), and a canned-tune (Overkill PCM is not a canned-tune, it is as custom as you can get w/o him being in your car), you SHOULD not have any problems that would void your warranty.
    As mentioned by others at minimum you MUST have a scanner, if you are going to mod. Even the small things can have unexpected negative side effects.
    Note: it is possible if you go with a DP and hiflow cat you may set a DTC on your 04...this can be taken care of when adding the PCM.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  9. #9 Re: First mod decision
    Banned
    New Port Richey Florida
    Hey Listen to FasttKatt he knows is stuff when it comes to the 04+ gtps for tunning. He won't steer you wrong for anything for the car
  10. #10 Re: First mod decision
    GT Level Member Going Too Phast's Avatar
    Yup that is a solid game plan. You will feel a big improvement. Like IndeedSS said, Overkill's PCMs are not canned. He customizes it for your mods. You are getting the benefit of a guy who has LOTS of experience tuning these cars. He also has a lot more resources at his disposal. Like he says that he has worked with a tranny shop to get the line pressure set to be best for the tranny. Not something the casual tuner can do. I've have been very impressed with the tune I have. He can nail them down very well. He has a generous retune policy too. Retunes within 30 days only cost you shipping. You can send him scans and he can make changes if they are needed. Not everyone has the time or money for a tuner (and laptop if you don't have one). To learn how to tune is going to take hours and hours and you'll be burning a lot of gas too. I learned from my experience tuning carburetors that I much rather have someone else mess with that!
    On the intake, I've got a Wizaired. It is a nice setup and I like it, but really there are cheaper alternatives. If you are on a budget I'd try something else and use that money for other go fast goodies.
    .: 1998 GTP : 3.5 : PT : 1.9s : Intake : DP : Plog : 180* : 605s : UD WPP : STBs : 12" Brakes :.
