97 gtp 70k miles. On cold starts or if the car sits longer then 30 minutes after being driven it cranks for at least 5 full seconds before it starts, it used to fire up with the tap of the key. I tested the fuel pressure with the key on engine off, the pressure goes up to about 50 while the pump is priming, then when the pump shuts off it takes about 30 seconds for the pressure to go to 0. With it running pressure is at about 45 psi at idle and raises slightly when i blip the throttle. I dont think its the fuel pressure regulator because there was no signs of gas in the vacuum line when i pulled it off, and when its running and i disconnect the vacuum line to the fpr the pressure jumps from 45 to 55 so it seems like it is working properly.
Is there a check valve somewhere in the fuel system that is supposed to hold pressure when the pump is off, on the fuel pump maybe? could that be the issue?
