Thread: 2000 Grand Prix GT starts easily then dies after 2-3 seconds
Results 1 to 6 of 6
  1. #1 2000 Grand Prix GT starts easily then dies after 2-3 seconds
    Jun 2014
    Texas
    My 2000 GT with the 3.8 has been running ok. It has had a little hesitation first thing in the morning, but overall ok. The other day when I got off work I start it up and then it just dies like it is out of fuel. It starts right back up, but will only run a few seconds and just cuts off. I checked the fuel pressure and it is good at 45#, even after it dies. Replaced the MAF sensor and no help. Same problem. Same symptoms every time, runs a few seconds and cuts off. I haven't ran the codes yet. Any ideas?
  2. #2 Re: 2000 Grand Prix GT starts easily then dies after 2-3 seconds
    Apr 2015
    Columbus, OH
    I would have it scanned.
    Top Swapped 01 Imp
  3. #3 Re: 2000 Grand Prix GT starts easily then dies after 2-3 seconds
    Jun 2014
    Texas
    I ran the codes and got "P1629"
  4. #4 Re: 2000 Grand Prix GT starts easily then dies after 2-3 seconds
    Mar 2014
    Tucson
    P1629
    Description
    THEFT DETERRENT CRANK SIGNAL MALFUNCTION
    Vehicle operation is disabled if incorrect key or starting
    procedure is used. Vehicle Theft Deterrent (VTD) module enables crank
    circuit to starter and sends a signal to PCM if correct key is being
    used. If proper signal does not reach PCM fuel enable signal circuit,
    PCM will not pulse injectors on, disabling vehicle, even if crank
    circuit is by-passed. Signal should be between 40-60 Hz and is
    measured using DC scale on DVOM.
    Symptoms
    Engine will not run
    Causes
    PCM detects incorrect signal on theft deterrent fuel enable
    circuit.
    Solutions
    Check for faulty connection at TDS module.
    Bypass VATs(92-99 only) ← Had to do this on my '96 Cutlass. Some radio shack resistors and heat shrink tube, and I was rolling again.
    Replace VTD module.
  5. #5 Re: 2000 Grand Prix GT starts easily then dies after 2-3 seconds
  6. #6 Re: 2000 Grand Prix GT starts easily then dies after 2-3 seconds
    Jun 2014
    Texas
    It consistently gives that P1629 code, but the "security" is not showing on the display and the light on the dash is not on or blinking.
  1. 2001 Grand Prix starts up and shuts off in seconds.
    By pinkdervish in forum General Grand Prix Discussion
    Last Post: 01-20-2014, 03:42 PM
  2. 2004 grand prix gt starts then dies within 2 seconds (intermitten)
    By GRANDPRIX2004 in forum General Tech Discussion
    Last Post: 03-12-2013, 07:07 PM
  3. Cars starts then within seconds DIES!
    By MistyChameleon in forum General Tech Discussion
    Last Post: 07-15-2011, 03:34 PM
  4. GTP Starts and dies after 4-5 seconds, revving the engine keeps it running
    By 93Chewbacca in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2011, 09:38 PM
  5. 90 Grand Prix starts, then dies
    By Fishhead5 in forum General Tech Discussion
    Last Post: 06-05-2009, 10:35 AM
