Thread: misfiring but no code
Results 1 to 11 of 11
  1. #1 misfiring but no code
    SE Level Member firefighter6180's Avatar
    st louis
    ok the title doesn't do this justice,
    couple days ago i had a misfire, the ses blinked at me when car was going up hill but never did it again, found a p0303 and changed the wire and spark plug on cylinder 3, now it still misfires under load but no light or when i start it, it will have a rough idle and sputter constantly but it is either one or the other and not all the time. So im stumped, i was considering fuel pump, fuel pressure regulator or fuel injector since im not getting a code anymore? i have not tested the coil yet
  2. #2 Re: misfiring but no code
    could be a clogged cat. how many miles you have and year?
    try swapping injectors around, and the coils around, if the misfire moves the last one you changed is the problem.
    or a bad icm, the part under the coils, it could be bad.
  3. #3 Re: misfiring but no code
    GT Level Member mkyota1's Avatar
    Daytona, florida
    How old are the rest of the plugs and wires? If old I would start there first. Do you know anyone with a decent scan tool that will show individual cylinder misfires? This would be the easiest way to see which ones are causing the problems.
  4. #4 Re: misfiring but no code
    st louis
    i will try moving parts around first and go from there, its 2002 gt with 211,00, headers, magnaflow exhaust system rear 02 delete, and k+n air intake
  5. #5 Re: misfiring but no code
    st louis
    im on duty tmw so ill be back on friday, would sea foam help? thanks for the replies
  6. #6 Re: misfiring but no code
    i dont think it will clear up a misfire, if thats whats going on.
    no o2 in the back, so you got a hi flow or no cat installed?
  7. #7 Re: misfiring but no code
    Feb 2013
    37.295091, -121.930053
    im going with scotty on this one.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  8. #8 Re: misfiring but no code
    Daytona, florida
    If the cyl misfire code is not reseting it will not do any good swapping parts around because you will not know is the problem has moved. Do you not have access to a scanner as asked before?
  9. #9 Re: misfiring but no code
    st louis
    high flow cat, and i have a 3100e innova code reader, is that what you mean by scanner
  10. #10 Re: misfiring but no code
    Daytona, florida
    If you go into live data does it show you cyl 1 misfire, cyl 2 misfire etc in the data. If so you can look to see where your misfire is coming from. If your scanner does not show those it may be worth finding someone with one that does. The pcm must see a certain number of misfires within a certain amount of time to set a p0301 or p0302 etc. That is why it is not setting a code or the check engine light right now, it is not seeing enough even though you can feel an obvious misfire.
  11. #11 Re: misfiring but no code
    Daytona, florida
    Alright man i looked up specs on your scan tool and it does not look like it shows live data. Sorry so this wont really help you out much. I cant be of much help without knowing what cyl is currently misfiring.
  1. 05 Misfiring
    By PontiacL32 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2012, 11:34 PM
  2. Misfiring
    By beetlebugman in forum General Grand Prix Discussion
    Last Post: 08-29-2012, 08:08 PM
  3. Misfiring HELP!!!!
    By Grandprix07gt in forum General Tech Discussion
    Last Post: 03-07-2011, 04:17 PM
  4. Random Misfiring P0300 Code
    By spcguy88 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2010, 09:44 PM
  5. Misfiring?
    By hotshot in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-05-2008, 09:33 PM
