Thread: P0303 - Cylinder #3 Misife ...
Results 1 to 12 of 12
  1. #1 P0303 - Cylinder #3 Misife ...
    Shelby Township
    I took my grand prix into autozone and found out I have error code: P0303 - Cylinder #3 misfire.
    I just replaced all six spark plugs and all the spark plug wires, and no difference. The code still appears.
    The next step I'm going to take is replacing the coil packs. Is there a way to test which coil is bad ? Do I need to replace all three coils?
    Any help would be appreciated.
    Thanks,
    -Nick-
  2. #2 Re: P0303 - Cylinder #3 Misife ...
    Barksdale AFB, LA
    If you're having trouble with #3, replace the coil pack responsible for #3.
    There are three things required for a proper combustion cycle. Fuel, air, and spark. Air is pretty much taken care of by the valve opening. Fuel, if you're injector is sticking or something then you're probably going to get a very weird running engine. Spark, you're already on the right rack with that.
    2009 Subaru Impreza WRX STI
  3. #3 Re: P0303 - Cylinder #3 Misife ...
    GT Level Member WhiteGT's Avatar
    May 2008
    Ontario
    You can test the resistance across the coil packs with on ohm meter. Place the leads across the 2 pegs that the plug wires connect to on the pack and compare the readings between the 3 packs, they should all be fairly close. But like sabrewings said if it says cyl#3 then that's most likly the bad pack. When you change it it's not a bad idea to take the whole ignition module off and clean off the corrosion that will most likly be behind it.
  4. #4 Re: P0303 - Cylinder #3 Misife ...
    Shelby Township
    Thank you very much for the help.
  5. #5 Re: P0303 - Cylinder #3 Misife ...
    Oct 2008
    Kansas
    Did you get your problem figured out?
    I was of the understanding, with the type of coils on this engine, typically both sides of the coil go bad at the same time. Therefore 2 cylinders would misfire. Is this not correct?
  6. #6 Re: P0303 - Cylinder #3 Misife ...
    Hoffman/Schaumburg, IL
    ^^It can be, but sometimes the coil shorts or carbon tracks and only one cylinder gets it, the free way to test a coil is to switch it with another of the coils and see if the missfire follows
  7. #7 Re: P0303 - Cylinder #3 Misife ...
    Shelby Township
    Problem solved and my car runs beautifully. It must have been either the spark plugs or the wires because I replaced them both and it runs like a champ now.
  8. #8 Re: P0303 - Cylinder #3 Misife ...
    Oct 2008
    Kansas
    Excellent! Congrats!
  9. #9 Re: P0303 - Cylinder #3 Misife ...
    Nov 2008
    Central NJ
    I"m just a little confused as to what your last fix was. Did you change the coil(s)? Did you replace the plugs and wires a second time?
    I'm having some trouble with my 99 GTP and I have already replaced all 3 coils, ignition module, plugs and wires. I'm getting a code for misfire in cylinder #1. The Pontiac dealer in my area is more concerned with selling me on anything else except for fixing my problem.
  10. #10 Re: P0303 - Cylinder #3 Misife ...
    Shelby Township
    I replaced all of my spark plugs and bought new wires. That did the trick and everything is working great now.
  11. #11 Re: P0303 - Cylinder #3 Misife ...
    Oct 2008
    Kansas
    Bandit1228,
    Keep in mind that even new parts can be bad. It's frustrating I know. Try swapping your coils around and test the resistance of the plug wires. Sometimes new plugs can be faulty too. Never hurts to double check things anyway.
  12. #12 Re: P0303 - Cylinder #3 Misife ...
    Shelby Township
    Yeah definitely check your coil packs next.
  1. Master Cylinder Cap
    By offroadfury6 in forum Brakes/Suspension/Chassis
    Last Post: 08-22-2008, 10:43 AM
  2. cylinder head gaskets
    By jdevier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2008, 09:33 AM
  3. P0300 multiple cylinder misfire code
    By Reeddawgy in forum PCM Tuning
    Last Post: 07-15-2008, 07:42 PM
  4. gtp cylinder heads
    Last Post: 06-05-2008, 06:29 AM
  5. #4 cylinder misfire
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 06:16 PM
