Thread: Engine Bracket
Results 1 to 12 of 12
  1. #1 Engine Bracket
    May 2011
    omaha, NE
    I need to replace the engine bracket on the passenger side. It is the U shaped one that bolts down onto the engine mount that that looks like this.
    Uploaded with ImageShack.us
    I have been looking around on the internet and I am having trouble finding information about it. I was wondering if anyone knew the easiest way to change it.
  2. #2 Re: Engine Bracket
    thats called a motor mount.
  3. #3 Re: Engine Bracket
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    What you have there is a Hydraulic Motor Mount. Easiest way to change it is to first, remove passenger wheel, then jack the vehicle up using the passenger from side jack point(Be sure not to jack it up using the subframe because this is what the motor rests on). Unbolt your dogbones(upper engine mounts), loosen the 4 bolts on the motor mount itself, to do this your going to need an offset 15mm wrench to fit into the subframe on the passenger side to get the ones on top of the motor mount itself which are bolted to the engine-to-motor mount-bracket-thing. Then, after removing the bolts, get yourself a 2x4 and place it inbetween the oil pan and tranny pan and begin to slowly jack the motor up until the motor clears the motor mount and it should be easily removed. Then rewind for install. A new motor mount should run you about 40-60bucks at Napa/Autobone/Oriellys.
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
  4. #4 Re: Engine Bracket
    Omaha, NE
    Quote Originally Posted by sdavis11b View Post
    How do you remove a wheel without jacking the car up?
  5. #5 Re: Engine Bracket
    Atlanta, GA
    loosen the lugnuts then "Jack-up" the car, THEN remove the wheel.......
    Cmon now
  6. #6 Re: Engine Bracket
    May 2011
    omaha, NE
    I know that is the motor mount I could not find a picture of the bracket that I need to replace. The bracket that I need to replace is the u shaped bracket that sits on that mount.
  7. #7 Re: Engine Bracket
    You made it too easy.
    Bracket eng mt: Part 10321856
    Here's a picture, it's part #1
    Pontiac 2000*Grand Prix*6-CYLINDER ENGINE*1997-2003 W ENGINE & TRANSMISSION MOUNTING (L67/3.8-1)* Car parts for your Buick, Cadillac, Chevrolet, Hummer, Light Truck, Oldsmobile, Pontiac, and more!
    I find a ratcheting wrench is the easiest way to get to the bolts. You could pull the rubber mount out, then get that bracket off w/o pulling the subframe. It's a bit of a pain though.
  8. #8 Re: Engine Bracket
    Topeka, KS
    Here's a writeup from my local forum. Kansas City Pontiac Motorsports Club - Login
  9. #9 Re: Engine Bracket
    You have to be a member to see it now Ryan.
    Also adkaven...opt for the solid rubber replacement mount, not the fluid filled hydraulic one. That way you won't be replacing the mount again.
  10. #10 Re: Engine Bracket
    Grand Rapids, MI
    and while you're at it, replace the tranny mount on the driver's side with the solid replacement as well...because it will fail once you replace the engine mount. it did that on mine
    but the tranny mount is easier than the engine mount so no extra work really.
  11. #11 Re: Engine Bracket
    let's keep in mind that the solid engine mount requires you to add spacers to make up for the space that the hydraulic fluid isn't taking up or your engine looks like it's sitting 1/2" or so too low on the passenger end.
  12. #12 Re: Engine Bracket
    May 2011
    omaha, NE
    Ok thanks for the input. I will probably be working on it in the next week or so.
  1. Name this bracket.... Thanks
    Last Post: 10-21-2009, 07:23 AM
