Thread: car stumbles at 3200 rpm please help
Results 1 to 3 of 3
  1. #1 car stumbles at 3200 rpm please help
    GT Level Member chamberlain198437's Avatar
    Grants Pass Oregon
    My car is has been having a stumbling problem the past few days. While driving the car stumbles at 3200 rpm, and then clears out after about 3500 rpms. It also does this the whole time when you floor it. It almost sounds like its lean poping in the exhaust.I did notice the engine trys to throw more boost at it when it stumbles. When it first started I was at a stop light and noticed the rpms going up and down about a 100 rpms. After doing this at the stop light it hasnt done it since then. The car does not do this while its in park it revs up fine, it has to be under a load. I checked the resistance in the coil packs they checked out good, and I checked the plug wires. I replaced the spark plugs last may, I havnt looked at them yet but im guessing there fine, there autolite iridium plugs. I replaced the fuel filter a few months back, not that a filter would cause a problem this bad.The car has a L67 with about 115000 miles on it, so its expected that things are going to start to go out in it. Any help on this would be much appreciated thankyou!!!!
  2. #2 Re: car stumbles at 3200 rpm please help
    bad maf?
    or clogged cat?
  3. #3 Re: car stumbles at 3200 rpm please help
    Grants Pass Oregon
    theres no cat on the car, im going check the maf next. Im guessing that it might be the cause beause I know they dont always throw codes when they go bad
  1. stumbles, misfire?
    By alivepills in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-22-2011, 09:31 AM
  2. 97 3.1L wont start, stumbles and dies
    By atxjax in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-16-2010, 03:18 AM
  3. Car stumbles after startup and has a jumpy idle
    By Lionel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-16-2009, 07:23 PM
  4. Buying a used torque converter? Its an ATI 3200 stall...
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-24-2008, 06:00 PM
