Thread: Surging Through Low Speeds and No Check Engine Light
Results 1 to 5 of 5
  1. #1 Surging Through Low Speeds and No Check Engine Light
    SE Level Member NapNinja317's Avatar
    Indianapolis IN
    Im usually pretty good with cars but this has me stumped. I have a 1997 Pontiac Grand Prix GT 3800 and Im having problems. It seems to surge on acceleration through first and second until about thirty miles an hour but none after that. Also I went to check the codes and a scanner wont connect. When I turn on the car I get no check engine light like I should before the car is started. Could a burnt out light cause the car to stay in open loop and give me the bad gas mileage im getting? Also, could the surging just be caused by bad plugs or because the computer might be bad? Any help on some diagnosing this would be great. Should I check the light first to see if it is burnt out? How do I go about doing that?
  2. #2 Re: Surging Through Low Speeds and No Check Engine Light
    Indianapolis IN
    Okay so my cig lighter doesnt work either and from on the board it says if it doesnt work then my aldl wont work. When my girl gets back from work Im going to check the fuse and replace it. Question is will this cause the light to not come on also?
  3. #3 Re: Surging Through Low Speeds and No Check Engine Light
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    i have kind of the same problem man. only mines with the 3rd and 4th. Bad gas mileage as well.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  4. #4 Re: Surging Through Low Speeds and No Check Engine Light
    Indianapolis IN
    No advice from any gm techs or anything...Something would help.
  5. #5 Re: Surging Through Low Speeds and No Check Engine Light
    Indianapolis IN
    Okay so I replaced the fuse last night and the light would still not come on but I did get a scanner to connect. It was simple cylinder 3 and 5 misfires and a random multiple cylinder misfire. That's no biggie just a simple tune-up. Now how do I go about changing this burnt out bulb?
  1. Check engine light on
    By CMURDAx in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2010, 10:11 PM
  2. Check engine light
    By Hawk656 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2009, 04:13 PM
  3. check engine light
    By cboth686 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-10-2008, 08:48 PM
  4. Check Engine Light
    By WHITE02GTP in forum General Tech Discussion
    Last Post: 10-08-2008, 10:31 PM
  5. Check Engine Light
    Last Post: 09-01-2008, 09:01 PM
