Thread: Rebuilt Trans in February - 3rd to 4th Gear Problems w hardened installed
Results 1 to 20 of 25
Threaded View
  1. #1 Rebuilt Trans in February - 3rd to 4th Gear Problems w hardened installed
    GT Level Member SliceTheRice's Avatar
    South Jordan, UT
    Hey Guys,
    As I understand it, there is an ECM which is responsible for engine management, a TCM which is responsible for transmission management, and a PCM is basically the ECM and the TCM together. If I'm not mistaken, on our cars the PCM is literally one phycical unit that houses the TCM and the ECM. Is that correct?
    Here's my problem (the VERY short version). My car is having major shifting problems where between 3rd and 4th gear the car starts jerking and bucking pretty hard. I had the tranny rebuilt back in February with a warranty so of course I took it back to the shop. The shop owner said the TC lock-up is occuring too early and as a result the engine bogs when lock-up occurs. The bog is then recognized and the lock-up is released. This cycles very quickly and causes the jerking/bucking sensation. He said he's extremely confident that a program reflash with the latest programming will fix the problem because it will make the computer delay the lock-up speed to where it should be.
    Right now I have a DHP 1.0 tune and my question is: Can I have a dealership reflash JUST the TCM and leave my ECM tune alone?
    Thanks for the help!
    2000 Pontiac Grand Prix GTP
    (3.4 MPS, DHP 1.0 tune, ZZP Plog & 3" DP, 2.5" cat-back exhaust, resonator delete, AL104 plugs, 180* T-stat, Falken Ziex 245/45/18 tires)
  1. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  2. Pours blue smoke, wont idle, check engine light flashes!?
    By 1fastz71 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-25-2010, 09:13 PM
  3. Right signal light flashes fast, left signal flashes normal speed?
    By nboylie in forum General Tech Discussion
    Last Post: 11-23-2009, 06:38 PM
  4. Security light flashes???
    By AKGTP in forum Audio, Security & Visual Electronics
    Last Post: 07-04-2009, 08:03 PM
