Thread: Shifting hard/jerking when shifting
Results 1 to 14 of 14
  1. #1 Shifting hard/jerking when shifting
    GT Level Member Jonarin's Avatar
    Oct 2014
    Hey guys, I just recently bought a 99 gtp. Anytime I drive the car normal, it shifts ok, still kinda hard. When I give it a lot of gas, it shifts really hard almost as it's jerking the whole car. The guy I bought it off of, just had the torque converter and flywheel replaced and fluid exchanged. Any ideas? Maybe a tranny or motor mount?
    Sent from my SM-N920V using Tapatalk
  2. #2 Re: Shifting hard/jerking when shifting
    have it scanned after it acts up, do not turn the car off, scan it running still. you should have a pending code for max adapt shift. if you do a shift kit is a good bandaid for it.
  3. #3 Re: Shifting hard/jerking when shifting
    Oct 2014
    I asked the guy that I bought it from, and he sent me a link of a shift kit he put jn. It's a thrasher one
  4. #4 Re: Shifting hard/jerking when shifting
    damn.... still have it scanned. likely theres a code popping up for it.
  5. #5 Re: Shifting hard/jerking when shifting
    Oct 2014
    He said that it's the shift kit that I'm feeling. He said it's supposed to **** harder than normal..
  6. #6 Re: Shifting hard/jerking when shifting
    Oct 2014
    I'll go check the codes now
  7. #7 Re: Shifting hard/jerking when shifting
    i have a trans tune, and a shift kit. it does shift firmer, but not like its shaking the car apart. just a snappy shift.
  8. #8 Re: Shifting hard/jerking when shifting
    Oct 2014
    That's pretty much what it is.
  9. #9 Re: Shifting hard/jerking when shifting
    Kemmerer, Wyoming
    I'm not sure about the thrasher shift kit, but other kits have firmness levels. the transmission I have, and the shift settings in my computer will chirp the tires on a 1-2 shift when the pedal is pushed down all the way, which you can probably imagine is a hard shift.
  10. #10 Re: Shifting hard/jerking when shifting
    Oct 2014
    I am in the car now, no codes whatsoever
  11. #11 Re: Shifting hard/jerking when shifting
    mine still dont chirp second gear
  12. #12 Re: Shifting hard/jerking when shifting
    Oct 2014
    Maybe it's normal. I'm thinking it's the thrasher shift kit.
  13. #13 Re: Shifting hard/jerking when shifting
    Kemmerer, Wyoming
    Quote Originally Posted by ScottyDoggs View Post
    your power level should be there, maybe if you had some transmission work done, or a more aggressive trans tune. my shift time is .0125 in pe mode
  14. #14 Re: Shifting hard/jerking when shifting
    it just shifts and goes fine. im good with no chirp, chirps break stuff i bet, being my tranny is stock.
  1. Hard shifting
    By Jonarin in forum General Tech Discussion
    Last Post: 04-20-2015, 11:53 AM
  2. Shifting hard
    By zildjian102 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-25-2011, 08:25 PM
  3. shifting hard
    By jaredbos 1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-16-2011, 12:25 AM
  4. Maybe shifting too hard?
    By Claude in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-27-2010, 08:31 PM
  5. Hard shifting
    By Seagya in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2009, 09:50 AM
