Thread: Torque Strut Mount Bracket Passenger Side
Results 1 to 4 of 4
  1. #1 Torque Strut Mount Bracket Passenger Side
    Apr 2012
    Alexandria, VA
    I have a cracked passenger Strut Mount Bracket on my 2001 Grand Prix GT. See pics. It looks like the outer fork is still in one piece and not cracked. If anyone has one laying around, let me know.
    http://s1052.photobucket.com/user/Lo...t%202.jpg.html
    http://s1052.photobucket.com/user/Lo...mount.jpg.html
    Thank you!
    Matt
    PM me or email louie1462@gmail.com
    p.s. I titled
  2. #2 Re: Torque Strut Mount Bracket Passenger Side
    GTP Level Member
    Jun 2016
    Cleveland ohio
    If the one from 04 up will work shoot me an offer.
    http://i511.photobucket.com/albums/s...ps64zshzts.jpg
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  3. #3 Re: Torque Strut Mount Bracket Passenger Side
    Apr 2012
    Alexandria, VA
    Quote Originally Posted by rickisrad View Post
    I'm unsure but I'm going to guess it won't. Yours is a L67 and mine is an L36. Perhaps the brackets are identical. I'd need someone more knowledgeable to say. Thank you though!
  4. #4 Re: Torque Strut Mount Bracket Passenger Side
    hangover park IL
    the OEM fix for this issue in the earlier days was to install the iron SC bracket. those things break far too often expecially after a service job where it is removed. they much be gently snugged up on the aluminum side carefully only to 30/35 ftlbs (m101.5 bolts are capable of more but it shouldn't be tight enough to stress the brittle aluminum sideways).... then tightening the steel portion to keep the aluminum from being twisted under stress.
    with the iron sc tensioner/idler/ICM bracket you need the bolts from the donor car and it bolts right on, you can cut off the forward pulley boss if youd like, that was what was done as well as leaving the sc belt tensioner off, at that point you cant tell its not like that off the assembly line
    ~James~ Psychotic Gearhead
  1. Need aluminum motor mount bracket
    By pontiacGTP123 in forum Wanted To Buy - Parts
    Last Post: 03-13-2014, 08:18 PM
  2. Grand Prix motor mount bracket
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 03-13-2014, 12:18 AM
  3. 2007 GP Base Engine Torque Mount Bracket Passenger Side
    By eetchickn in forum Wanted To Buy - Parts
    Last Post: 09-04-2013, 05:27 PM
  4. L67 coil mount/engine mount bracket (passenger side) on an L36
    By BlownBigBlock in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-28-2012, 10:08 AM
  5. Cracked upper motor mount bracket
    By vailskier3 in forum 04+ Specifics
    Last Post: 04-16-2012, 02:11 PM
