Thread: 04-08 Projector Retrofit housing install?
Results 1 to 6 of 6
  1. #1 04-08 Projector Retrofit housing install?
    May 2008
    Winnipeg, MB
    Just a question regarding the install of the headlight housing with the projectors in them. Classy Retrofit projector headlight housings. What needs to be done to the car itself to make the housings fit? Something behind them needs to be cut, what kind of tools do people use? Any pictures of said modification?
    2007 Pontiac Grand Prix
  2. #2 Re: 04-08 Projector Retrofit housing install?
    You have to cut a bit of the metal behind the headlight
    http://www.grandprixforums.net/threa...-08-Headlights
    04 Comp G.
  3. #3 Re: 04-08 Projector Retrofit housing install?
    May 2008
    Winnipeg, MB
    oh that is easy, just need a 2" hole saw bit for my drill to go through some plastic on the car behind where the projector is sitting
  4. #4 Re: 04-08 Projector Retrofit housing install?
    You might have to cut into the metal bracing too. It just depends on clearance and what projectors you go with and how far back they're mounted.. Easy fix.
    04 Comp G.
  5. #5 Re: 04-08 Projector Retrofit housing install?
    May 2008
    Winnipeg, MB
    the projectors Classy Retrofit uses, think they are Morimoto Mini H1 6.0
  6. #6 Re: 04-08 Projector Retrofit housing install?
    GTP Level Member
    Sep 2011
    Motown
    The 6.0s were redesigned many times since that thread was made. The projectors sit much farther back no with new bowl design and with the new Morimoto bulbs. You will most likely have to cut some metal away. A drill, dremel, etc would be an ideal tool. We use a rotary file when doing installs on vehicles.
    Quote Originally Posted by deadwoodspecial View Post
    On a side note, I do want to add that Classy is keeping it classy through all of this. The guy has a hell of a business ethic, and is doing everything possible to make this right. If anyone was, is, or has considered getting retro's, I HIGHLY recommend him. Good prices, and he backs his sh!t.
  1. 04+ Projector Retrofit
    By Koniig in forum Visual/Body Modifications
    Last Post: 07-10-2017, 03:02 PM
  2. Projector retrofit in a '97-'03
    By barnettimpala in forum Visual/Body Modifications
    Last Post: 02-15-2013, 05:43 AM
  3. Retrofit projector help please
    By szalajka05 in forum Visual/Body Modifications
    Last Post: 04-21-2012, 06:24 AM
  4. My Projector Retrofit
    By Dawings33 in forum 04+ Specifics
    Last Post: 09-06-2011, 09:49 PM
  5. Projector retrofit
    By rocket69GTP in forum Visual/Body Modifications
    Last Post: 04-17-2011, 12:46 PM
