Thread: Tinting windows
Results 1 to 20 of 25
  1. #1 Tinting windows
    About to tint my windows..Would a heatshrink gun work a lot better than just pushing the water from the center out? I would think so.
  2. #2 Re: Tinting windows
    I live here. UR LOSN's Avatar
    Rockford, IL
    heating it up does help out, but too much you will distort it......
  3. #3 Re: Tinting windows
    PA
    I think most of the pros use a heat gun. But there is a fine line between drying the water out and melting the tint.
    I have tinted a few cars myself before. But with the curves that many cars have in the glass, it is just much easier to pay someone to have it done.
    2001 GSE
  4. #4 Re: Tinting windows
    SE Level Member scooz14's Avatar
    West Bloomfield MI
    heat gun on the outside of the window, after you have pushed as mush water as you possible can out. the heat is what really sets the tine on the window
    12.591@108.00 1.95 60'
    329.9hp 400.1tq
    http://www.mccgp.com/member_details.php?mid=95
  5. #5 Re: Tinting windows
    Oklahoma
    Can you remove the rear window tinting without damaging the defroster elements? If so, how do you do that? Mine is bubling up back there and making it increasingly difficult to see out of.
  6. #6 Re: Tinting windows
    PA
    I need to do the same thing. But I am going to get it re-tinted afterwards, so I will just let the tint shop remove it for me.
    2001 GSE
  7. #7 Re: Tinting windows
    Rockford, IL
    there is a spray called "tint off" you just spray it on the window tint.....and it should just easily peel off. it loosens up the adhesive or you could just take a razor blade and cut it all out....
  8. #8 Re: Tinting windows
    GT Level Member Chleby's Avatar
    Sioux Falls, SD
    Quote Originally Posted by UR LOSN View Post
    don't use a razor blade on the rear window because you could easilt damage the defrosting elements
    2001 Grand Prix GT...turbo build soon to come
    http://www.cardomain.com/ride/2618949
    Andrew Chleborad....Sioux Falls, SD
  9. #9 Re: Tinting windows
    Rockford, IL
    kinda meant it as a joke......guess I kept a straight face on that one....
  10. #10 Re: Tinting windows
    Oklahoma
    Thanks Man, NOW you tell me after I have went out there and done it..
  11. #11 Re: Tinting windows
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    like it's really hard to keep a straight face on a message board post!
  12. #12 Re: Tinting windows
    Oklahoma
  13. #13 Re: Tinting windows
    SW Chicago Suburbs
    i think we need more smileys!!!!!!!!!!!!
  14. #14 Re: Tinting windows
    West Bloomfield MI
    i would recommend having the rear tint professionally removed.
    the older it is, the harder it is going to be to take off w/o destroying your defroster lines. take it to a place that way if they mess it up, they get to fix it.
    329.9hp 400.1tq
  15. #15 Re: Tinting windows
    Saraland Alabama
    Quote Originally Posted by scooz14 View Post
    best recommendation ever. I can do tint, but always take it and have it done, that way if I'm not happy I get to yell at someone that isn't in the mirror
  16. #16 Re: Tinting windows
    Louisville, KY
    Please don't use a razor blade on your back window. If you cut one of the lines it can mess up your rear defrost. Let the tint shop do it before they retint. I paid 130 to have mine tinted 20% with a lifetime guarantee as long as I own the car. If I don't use cheap cleaner and turn them purple, the tint shop will replace tint if it ever bubbled. Had it on 3 years with no problems. It's worth letting the professionals do it! Find a guarantee on the tint and the work!
    Maybe take out the rear deck so it's tinted over the third light too!
    My Cardomain
  17. #17 Re: Tinting windows
    Wichita, KS
    When I bought my car the tint that was in it was cheap "China" tint and had turned the usual nice shade of purple.
    I removed all my tint myself, its not hard to remove the tint...its hard to clean up the mess left behind.
    All I did on all of my windows was grab a corner and pull. Once it was off, I used a nice sharp razor blade and some Imperial Cleaner and that made clean up easy. I did not use the razor blade on the rear window, I did use a really fine scotch bright pad though, and with the cleaner...it was easy as pie.
    Making a tint shop "replace" or "fix" your rear window if they f-it up is slim to none. Your better off doing it yourself. Plus, it will make the price of the new tint cheaper if all the old tint is removed and the windows cleaned.
    I had my car tinted with commercial grade metallic film, that is 20% and meters at 17%, the entire rear glass was done in one solid piece of film, so I have no seams or gaps, I paid $100.00 with a life time guarantee.
    ~F~
  18. #18 Re: Tinting windows
    Saraland Alabama
    Quote Originally Posted by GR8racingfool View Post
    ~F~
    I worked at a shop that did tint (car stereo store/distributor), and if there was any problem we redid it, a good shop will stand behind their work, a bad shop tells you to get lost.
  19. #19 Re: Tinting windows
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    Quote Originally Posted by archemedes View Post
    This has always been my experience also, but was he talking about actually messing up the back window, and not the tint? Either way it shouldn't be a problem with a good shop.
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  20. #20 Re: Tinting windows
    Wichita, KS
    I know what you meant. It just amazes me how many of these "good shops" are still in business in Wichita here. You ask any car guy, and they persionally have dealt with about everyone, or know someone who has, and there is only that 2% of shops here that will stand behind their work, or stand behind any damage done to your car while its in their shop.
    My guy is one of those 2% business. I'm going to have him come out, and tint several of the new windows I plan to put in on my home.
    ~F~
  1. Repair Your Power Windows Switch[*]
    By J_Ferguson in forum How To Write-Ups/Tech Tips
    Last Post: 10-19-2013, 01:07 AM
  2. Tail-Lights Tinting [*]
    By John02Hawk in forum How To Write-Ups/Tech Tips
    Last Post: 07-08-2010, 01:09 AM
  3. Final step of tinting my tails need a lil help please
    Last Post: 12-27-2007, 08:44 AM
