Thread: Headlight adjustment screw issues
Results 1 to 4 of 4
  1. #1 Headlight adjustment screw issues
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    I have replacement headlights that are retrofitted and my passenger side adjustment screw(the one to adjust the height of the light output) doesnt get as high as I need it to be. Seems that it will get up to a certain point and even though the screw will still turn, the light wont go up anymore. Any ideas on how to fix this?
  2. #2 Re: Headlight adjustment screw issues
    Jul 2010
    Coquitlam,BC,Canada
    New adjuster or new h/l housing frame.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #3 Re: Headlight adjustment screw issues
    GT Level Member April Thompson's Avatar
    Dec 2014
    Moline, IL
    I noticed on my '04 the dip (low) beam has a smaller lens over the bulb, and an adjuster controlled by an E-Torx bolt; can these smaller lenses be adjusted to aim toward the left side of the road... say, if I imported it to Scotland (as an example)?
    2004 Grand Prix GT2-clone A.K.A. the "Cybercar;" Galaxy Silver; 146K miles; RETROFITS: leather-wrapped steering wheel (w/audio controls) & shift knob; trip computer; map lights & dual lighted vanity visors; heated (?) leather seats w/ 10-way power driver's seat; ​HUD conversion
  4. #4 Re: Headlight adjustment screw issues
    Nov 2012
    Madison
    The adjuster is just for elevation(vertical) adjustments.
    The cup over the light is to prevent glare(blinding oncoming drivers) and a more evenly distributed light pattern. It can't be adjusted.
    I believe you are referring to right hand/left hand cut-offs found in a projector headlight.
    The states have a parallel step cut-off, projector headlight beam for left hand drive. Europe has a sweeping, whatever degree cutoff, whether it's right or left hand driving.
    But since you have a stock reflector headlight you don't need to worry about it.
  1. Headlight Screw
    By MattF in forum General Grand Prix Discussion
    Last Post: 01-04-2014, 09:35 AM
  2. Headlight adjuster screw
    By 1996pontiac in forum Visual/Body Modifications
    Last Post: 05-20-2013, 11:23 AM
  3. Headlight adjustment screw question
    By gordster1122 in forum Visual/Body Modifications
    Last Post: 10-25-2012, 03:26 PM
  4. Headlight Adjustment
    By 97GP in forum General Tech Discussion
    Last Post: 08-17-2008, 11:28 PM
  5. Headlight capsule adjuster screw
    By IndeedSS in forum General Tech Discussion
    Last Post: 06-07-2008, 05:03 PM
