Thread: Hid foglights
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21 Re: Hid foglights
    Pennsylvania, USA
    They don't help with glare, I just worded that a little strange. I prefer them for cheap HID kits, they have a good warranty and nice kits for the price. I do stick with their "digital slim" ballasts though. For quality HID kits I use www.theretrofitsource.com, but they can be pricey.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  2. #22 Re: Hid foglights
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by nik12937 View Post
    That's what I thought you meant. I agree with you; TRS stuff is top of the line.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #23 Re: Hid foglights
    Dec 2012
    Where 4T65E's were born
    Quote Originally Posted by Tyarne15 View Post
    To be honest, im not really looking for a lot of functionality with the HID's mainly just for looks as i think that the HID's make the car look alot better and alot meaner.
    That's all mine are for right now. They look really good in the daytime, makes my car more noticeable, especially on days with an overcast.
    One reason they glare so much is because the hid's don't have the light blocking front tip that the halogens do. So when you've got them on, you're looking straight at the HID bulb, which is never pleasant. The second reason is that the light source may not be in the exact same place as the old bulb, which causes the reflection pattern to change from the reflectors in the back of the housing.
    Here's what our fogs look like
    That tip stops you from looking directly at the filament.
    In a housing:
    If you were to scrape off that coating and re-install, the halogens would glare too. Probably not as bad as hid's due to the different light intensity. Then imagine moving the placement of the filament or hid, and the reflector would shine a different pattern.
    With the stock bulbs in the housings, pretty much all of the light was projected in a beam that stayed out of oncoming traffic's vision.
    You can see the beam here
    With the HID's, the light output is completely changed. I get a full circle of light that extends way past the hid beam. Just to make things slightly better, I aimed the fog lights as far down as they would go. This was the result
    Light still goes way too high, and the original beam pattern is completely changed. I want to try and replicate that light blocking coating on my hid's. Whether I coat it with something, or install some sort of cap over it, I'm not sure. If none of that works out, I will make some housings.
    Sold.
  1. 04+ foglights
    By dengnath in forum Audio, Security & Visual Electronics
    Last Post: 05-26-2011, 11:54 AM
  2. My JDM Foglights..
    By rocafella2032 in forum Visual/Body Modifications
    Last Post: 12-07-2010, 01:39 PM
  3. What foglights are these?
    By Frank217 in forum Visual/Body Modifications
    Last Post: 07-27-2010, 08:20 PM
