Thread: How do you remove the door from a 97 coupe
Results 1 to 8 of 8
  1. #1 How do you remove the door from a 97 coupe
    Donating Users joshuaandrew92's Avatar
    Jul 2010
    Bluffton, IN
    Asking exactly what the title says...
    Do you just remove the 4 bolts that attach the hinge to the door?
  2. #2 Re: How do you remove the door from a 97 coupe
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Just remove the 4 bolts and then there will be a wire harness connector that has to be unplugged and its off. On a 97 you have different style wiring connections than 99+ (I think) Anyways. If your swapping it out with a door from a different year save your old door harness.
    I went NA when a whore left -$300 in my bank account.
  3. #3 Re: How do you remove the door from a 97 coupe
    Jul 2010
    Bluffton, IN
    The door I'm picking up is on a 97 I will be installing on a 98
    Is it possible for the hinges to be removed from the body or are they welded... I believe mine are bad cuz my door sags a bit when it opens and catches the rear window molding when I shut it
  4. #4 Re: How do you remove the door from a 97 coupe
    Dec 2012
    Where 4T65E's were born
    My hinges are bolted on the door and on the car. So you can swap the hinges as well. If it's not aligned properly, it could just be how the hinges are aligned. There is some room to move the door up and down before tightening.
    Sold.
  5. #5 Re: How do you remove the door from a 97 coupe
    Jan 2012
    Indianapolis
    You can remove the hinges from the body. There is a torx to take them off tho. Not sure what size. It is small.
  6. #6 Re: How do you remove the door from a 97 coupe
    Jul 2010
    Bluffton, IN
    Thank you guys for your help I really appreciate it!
  7. #7 Re: How do you remove the door from a 97 coupe
    you can buy new hinges to fix your sagging door. no need for a whole door.
    if you open the door and lift it from the outer most side, (outside door handle side) and the door lifts up, the hinges are bad.
  8. #8 Re: How do you remove the door from a 97 coupe
    Jul 2010
    Bluffton, IN
    I know that I just need to replace my door anyway.. It's dinged and dented all to hell and paint is coming off of it
  1. How to Remove the B-Pillar + Top of the Door Weather Strip '97-'02
    By pgr1940 in forum How To Write-Ups/Tech Tips
    Last Post: 09-30-2016, 10:17 AM
  2. How do you remove the fuel door???
    By kirkkarem1212 in forum Visual/Body Modifications
    Last Post: 07-20-2010, 03:13 PM
  3. does anyone know how to remove the rails on the door safely?
    By rambo33 in forum Visual/Body Modifications
    Last Post: 09-13-2009, 12:51 AM
