Thread: LED third brake light.
Results 1 to 20 of 24
  1. #1 LED third brake light.
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    Could some kind soul who has installed LEDs in thier third brake light, please post a picture? I am curious how different a look the LEDs have over the conventional bulbs. Also, please state what type of LEDs you have in your third brake light, if you do post a picture. Thanks.
  2. #2 Re: LED third brake light.
    Mar 2013
    Manitoba, Canada
    Does anyone have LEDs in their third brake light?
  3. #3 Re: LED third brake light.
    GT Level Member Jakescoots's Avatar
    Spring Lake, Mi
    All the 04+ people do. Not certain about 97-03 though, but I don't think so
    Does removing the spare count as weight reduction?
    Badges on a car are just advertisements....Everyone already knows what it is. And if they dont, its a mystery. People like mysteries.
  4. #4 Re: LED third brake light.
    Yoga city
    when i had my 97 i wired in a led strip
  5. #5 Re: LED third brake light.
    Spring Lake, Mi
    My friend put an led panel up there
  6. #6 Re: LED third brake light.
    SE Level Member OldFart's Avatar
    Sep 2011
    Ontario, Canada
    I'm wondering the same thing as Kilroy. I installed new LED tails last week and the 3rd brake light looks rather lame now. Looking for an inexpensive LED mod. I'd like to hear about specific examples of what others have done. Pics would be appreciated!
    Stock 2001 GTP
  7. #7 Re: LED third brake light.
    Just put an LED bulb in that fits the socket.
  8. #8 Re: LED third brake light.
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    If you are looking to have brighter light I would suggest a LED bulb of some sort. If you are going to the individual bulb LED look like the tail lights I would suggest LED strips or something similar.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  9. #9 Re: LED third brake light.
    Mar 2013
    Manitoba, Canada
    Quote Originally Posted by burgundybullet View Post
    This is why I was hoping that if anyone has done ANY kind of LEDing to their third brake light, that they could post some pics so I can see what I think looks better, either just an LED bulb, or a strip, or????
  10. #10 Re: LED third brake light.
    I sould have quoted Old Fart because that was moreso directed at him.
    As for you do you have LED tails on the car?
  11. #11 Re: LED third brake light.
    Mar 2013
    Manitoba, Canada
    Yes, I have everything in the rear of my car LEDed.
    Sent from my GT-N8010 using Tapatalk 2
  12. #12 Re: LED third brake light.
    Jul 2010
    Coquitlam,BC,Canada
    I have Putco LED bulbs in my 3rd brake light, but no pics. I can hardly tell the difference, so visually they aren't worth it. I want to do an LED strip or retro something from another vehicle.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  13. #13 Re: LED third brake light.
    Sep 2011
    Ontario, Canada
    Thanks for the responses
    I don't know much about LEDs but I've looked at replacing the bulb with an LED equivalent. (1141 I believe?) It seems to me that the OEM lens would render this pretty much pointless. Bronco Boy seems to confirm this. I wonder if there are 1141 LED direct replacement bulbs in red that I could use, while removing the OEM red plastic lens? Does this sound like it might work?
    This is all new to me so I'm looking for any and all ideas. Doing LED strips as burgundybullet suggests sounds interesting but I know nothing about wiring them up or what to order. Suggestions on this idea are most welcome.
    Stock 2001 GTP
  14. #14 Re: LED third brake light.
    I would suggest taking out the rear deck and looking for a way to install some LED strips in it. That way it will match your LED tails. At least thats what I would do in your situation.
  15. #15 Re: LED third brake light.
    Quote Originally Posted by OldFart View Post
    I don't know much about LEDs but I've looked at replacing the bulb with an LED equivalent. (1141 I believe?) It seems to be that the OEM lens would render this pretty much pointless. Bronco Boy seems to confirm this. I wonder if there are 1141 LED direct replacement bulbs in red that I could use, while removing the OEM red plastic lens? Does this sound like it might work?
    If you are serious about wiring them I would suggest cutting the stock bulb plug and wiring them straight up to that using a 12v LED strip. Ill poke around and see If I can find something that would work for you.
  16. #16 Re: LED third brake light.
    Sep 2011
    Ontario, Canada
    Thank you sir!
    Much appreciated
    Cutting out the bulbs and splicing something into the existing wiring is not a problem. Just looking for something has a good chance of success and I'll give it a try.
    Stock 2001 GTP
  17. #17 Re: LED third brake light.
    Jul 2010
    Coquitlam,BC,Canada
    Ditto. The plan in my head was to re-use the light sockets to power an LED strip, but also use the sockets as a holder or mount, so the LED strip could be installed from the trunk, same as swapping the bulbs.
    You can also take an old bulb, remove the glass and solder wires to the base. I did similar on my fogs.....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  18. #18 Re: LED third brake light.
    Sep 2011
    Ontario, Canada
    Quote Originally Posted by Bronco Boy View Post
    Thanks! The visual is very helpful.
    I really appreciate the help, guys. My son is a car nut and the GTP has rekindled my enthusiasm as well. Little projects like this mean good times for us!
    Stock 2001 GTP
  19. #19 Re: LED third brake light.
    A light similiar to this may be what you need. http://www.ebay.com/itm/RED-9-LED-ST...b0d13c&vxp=mtr It might take a little work to get it mounted right but in the end I think it will looke good. You could probably get away with a white light but it may not turn out to give off a red look. Might be orangish coming throught the red plastic.
    And your welcome for the help.
  20. #20 Re: LED third brake light.
    Dec 2008
    Lawndale, CA
    Does replacing the 3rd brake light with LED's still cause issues with the cruise control feature on 97-03's?
  1. decisions on tail light tint, third brake light and reverse bar done
    By jteske88 in forum Visual/Body Modifications
    Last Post: 06-05-2012, 05:42 AM
  2. Trac off light, Brake light on?
    By 1badregal in forum Brakes/Suspension/Chassis
    Last Post: 10-17-2010, 10:24 AM
  3. Water in LR brake light housing/ABS light
    By andante147 in forum General Tech Discussion
    Last Post: 05-31-2010, 08:01 PM
  4. e-brake light
    By PNIGZ in forum Brakes/Suspension/Chassis
    Last Post: 02-26-2010, 06:12 PM
  5. my 4th brake light and 3rd reverse light
    By HART in forum Visual/Body Modifications
    Last Post: 11-05-2009, 01:33 PM
