Thread: DRL re route
Results 1 to 20 of 24
  1. #1 DRL re route
    Donating Users
    Plainfield, IL
    ok so i want my drls to power my parking light and fog lights instead of my head lights is this possible and how?
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: DRL re route
    May 2008
    McHenry IL
    interesting
  3. #3 Re: DRL re route
    TDCRacing
    Guest
    First off this is not in the right section. This is not a ''how to write up''.
    But to answer you're question you can just pull the DRL fuse located in the fuse box near the glove box. It should be a 10 Amp red fuse.
  4. #4 Re: DRL re route
    GT Level Member BackInBlack's Avatar
    Vermont
    See my web site.
    The GPs are long gone...
  5. #5 Re: DRL re route
    Donating Users Sykkel's Avatar
    Massachusetts
    gotboost3 thanks for posting this thread I've been looking to do the same thing. I have done the drl delete but would rather have my yellow parking lights be on during the day. It would save me from turning them on manually. I also have a set of halo projectors coming so thought it would be good to wire the halo's into the parking lights then have them run off the DRL. Anyone done this before?
    BackinBlack I don't see this on your site.
  6. #6 Re: DRL re route
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    that is exactly what i want to do. i dont really want the parking lights part. so in the long run when the drl come on it would be the halos and then still retain the automatic lights. i dont even know if that is possible. has anyone done it? also when it becomes night time would the drls turn off. i know that should be a no brainer but i didnt know if they would turn of since it goes strait from drl to low beams. any help would be awsome may that be telling me it will work or even more helpful by telling me how.
    silver 2003 Grand Prix GT List is on it's way to be updated
  7. #7 Re: DRL re route
    oklahoma
  8. #8 Re: DRL re route
    SE Level Member Slueth66's Avatar
    Nov 2008
    Iowa
    Is this for 97-03 prixs?
  9. #9 Re: DRL re route
    SE Level Member Agentlongwood's Avatar
    Nov 2009
    Orlando
    The pic that silver posted seems to be awsome and not too complicated. Just to clarify I want to be sure I understand it correctly... Following those steps The headlights will not turn on for DRL but the fogs will? And this maintains the automatic headlight functionality? And when the automatic headlights kick in it powers the headlights and I have manual control of the fogs with the foglight switch? I just got some HIDs and projectors in the mail and want to have the halos and fogs on for DRLs (powering the halos off the fog lights) and then normal lowbeams kick on when it gets dark out. Ton of questions I know lol, I just want to be sure before I start cuttin wires. Im not all that good when it comes to electrical.
  10. #10 Re: DRL re route
    Saskatchewan, Canada
    Just wondering...
    If you power your halos off the DRL, wouldn't they only be like 60% power and therefore not as bright?
    Just wonderin'...
    K
  11. #11 Re: DRL re route
    Nov 2008
    you could do it with a relay. kinda over kill but it would get rid of that problem if it is a problem
  12. #12 Re: DRL re route
    SE Level Member ChicagoGXP's Avatar
    Chicago
    Any idear how to due this on newer models? I have an 08 GXP and this is EXACTLY what I need. I cannot count the number of times I have been driving and not noticed I'm "strobing" until I get behind someone. Adding caps is not really something I would like to do (don't want the HIDs running 24/7) and disabling the entire automatic headlight system are just not ideas I'm willing to do.
  13. #13 Re: DRL re route
    Joliet, IL
    if im not mistaken there are DRL options in the newer model DIC's not positive on that tho.
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  14. #14 Re: DRL re route
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    Quote Originally Posted by silver View Post
    this will make my fog lights light up when i start my car during the day? or it will make them run with my headlights?
  15. #15 Re: DRL re route
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by BackInBlack View Post
    See my web site.
    will your DRL disable trick work on 04+ models? ( a 2006 )
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  16. #16 Re: DRL re route
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    you know if the switch to the fog lights is in the on position they will flash when you hit the lock and unlock buttons
  17. #17 Re: DRL re route
    GTP Level Member gpse2000's Avatar
    Apr 2011
    Fargo
    Quote Originally Posted by Taz Magester View Post
    That only happens for me about 1 out of 100 times lol
    I want just my fogs on for drls and not the Amber colored ones. Is that what the result of the pics above get me?
    2002 Denali Airaid MIT, Tint, 121k GARNET RED
    2006 GT S/C CAI, Plog, 3" DP, Flipped Mounts, DR STBs, SPO Grilles, SPO TIPS, Tint, Inlays, 120k BLEEN FOR SALE
    2000 SE 3.8 intake, dic swap, debadged, flipped mounts, rust mod 140k SILVERMIST SOLD
  18. #18 Re: DRL re route
    May 2011
    Canada
    Will this work on the newer style GPs?
  19. #19 Re: DRL re route
    GT Level Member Spartanzz's Avatar
    Dec 2010
    Lawrenceville, GA
    so still haven't found an answer to what this will do exactly???
  20. #20 Re: DRL re route
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Anybody have a wiring diagram for the DRLs?
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
